oil catch can behind block
Old Oct 8, 2012 | 03:52 PM
manoloek9's Avatar
Default oil catch can behind block
ok here's my question
can i take the can off and just plug it a seal ?
the reason im asking is because i have a plug that goes ther and my can it leaks oil bad and cant find one by were i live so i was woundering if i could run my engine like that......or will it damage it??
Old Oct 8, 2012 | 04:45 PM
ekcoupeh22's Avatar
Default Re: oil catch can behind block
B series? I wouldn't that takes the extra pressure out of the motor. It's only an o ring go to Honda and buy one for like a dollar
Old Oct 8, 2012 | 04:55 PM
manoloek9's Avatar
ITS NOT FROM THE O RING ITS THE CAN IT SELF THAT LEAK
Old Oct 8, 2012 | 04:57 PM
Fliptard's Avatar
take it off and clean it up and seal the leak with some JB weld or something. NO you can't take it off unless you buy a catchcan and the hardware to hook it all up.
Old Oct 8, 2012 | 05:04 PM
manoloek9's Avatar
OK KOO THANKS ILL THROW SUM JB WELD THANKS OR TRY TO FIND ONE THANKS FOR TIP BRO
Old Oct 8, 2012 | 05:46 PM
Fliptard's Avatar
should be able to find one at your local junk yard, if you jb weld, make sure all the oil is cleaned off it.
Old Oct 12, 2012 | 08:46 AM
manoloek9's Avatar
Oh ok koo
thewrai6th
Mar 9, 2015 01:36 PM
evosix
Aug 26, 2013 07:33 AM
ganjasnack
Aug 14, 2008 07:47 PM
GSR_hatch936
33
May 8, 2007 08:41 PM
97me03gst
Sep 17, 2004 04:26 PM
