Need ignition/fuel system B18c
Old Oct 8, 2012 | 03:22 PM
jr_soliz2010's Avatar
Default Need ignition/fuel system B18c
Ive looked and found a forum and posted my problem similar to what hte guy had but i wasnt getting a response so i gotta mke one for myself now.
No CELs
Cleaned IACV
Carbed vacuum lines for leaks-nothing
removed spark plugs to check for water-nothing
changed map sensor-nothing
removed fuel line to fuel filter to check fuel pump-working properly
resetted ECU and all fuses
Timing is on the dot
compression all 4 cylinders are 240ish
AEM fuel gauge reads 20 something on idle and 40ish on throttle
not overheating
tried everything everyone commented to that other forum and nothing seemed to work
so here is the story
B18C Block/ B16A Head, Bisi Header, BWR Intake Manifold, ARC Intake, AEM Fuel Rail, MSD Ignition Distributor, Crome Chipped P28 type r base map.(running rich)
Running rich i moved to Houston from El Paso drove car perfectly. Just recently purchased AEM Fuel Rail with fuel pressure gauge. Slapped it on, ran it for a couple weeks no problems. I was on my way to pick up a rad support and while i was on Beltway 8, 65 mph 5th Gear, it sputtered....then a little more, so i busted a U-turn and sputtered and hesitated to get above 3000 rpm each gear. Made it home, and this started happening.
any ideas?
Last edited by jr_soliz2010; Oct 8, 2012 at 04:12 PM. Reason: forgot to add stuff ive checked already
Old Oct 8, 2012 | 03:35 PM
djakob's Avatar
Default Re: Need ignition/fuel system B18c
I'm having almost the same exact problem with my d15b7 (https://honda-tech.com/forums/tech-misc-15/d15b7-bogging-wont-start-3094548/). Not trying to thread-jack, just would like to get some help with this!
Old Oct 8, 2012 | 03:44 PM
Originally Posted by djakob
I'm having almost the same exact problem with my d15b7 (https://honda-tech.com/forums/showthread.php?t=3094548). Not trying to thread-jack, just would like to get some help with this!
no problem man. if i can figure it out i'd hope it works for you too. lol does smoke come out of your intake? maybe its a conspiracy
Old Oct 8, 2012 | 04:15 PM
just checked the injectors...idk what im looking for but they seeem ok...not cracks or leaking anywhere
Old Oct 8, 2012 | 04:19 PM
ekcoupeh22's Avatar
Tried a different ecu?
Old Oct 8, 2012 | 04:23 PM
djakob's Avatar
My intake doesn't smoke. I just found this, not sure if you have looked at it yet or not: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/white-smoke-coming-out-intake-manifold-help-2909782/
Old Oct 8, 2012 | 04:29 PM
had a virgin p30 running for awhile then i sold it and started using my p28 so i can run it and see if any codes pop up so i can get the fuel/ratio tuned right. but both ecus were working fine.
Old Oct 8, 2012 | 06:56 PM
anyone?
alpha
Jun 14, 2003 07:19 PM
FastNFurious
Apr 12, 2003 05:54 PM
chiefvtec
Mar 3, 2003 04:23 AM
Kolijian
Jul 1, 2002 10:37 AM
