WTF is the name of this whole part?
Old Oct 8, 2012 | 12:51 PM
NOT An Obvious Troll's Avatar
Default WTF is the name of this whole part?
Cliffs:
- Car was broken into
- Broke ignition lock from the steering to unlock it
- Can't find the right combo of keywords to search for it, doesn't show up in Google
Pic:
it's a DB7 btw. Thanks in advance.
Old Oct 8, 2012 | 12:57 PM
DeCePtEgRa's Avatar
Default Re: WTF is the name of this whole part?
Should be able to buy just the inner barrel comes with new keys its called a ignition starter switch on rockauto.com 199.79 dont know how much it is at parts stores.
Old Oct 8, 2012 | 01:00 PM
Can you/anyone else be more specific?
Old Oct 8, 2012 | 01:05 PM
DeCePtEgRa's Avatar
Ignition starter switch
Old Oct 8, 2012 | 01:07 PM
DeCePtEgRa's Avatar
http://www.oreillyauto.com/site/c/se...gra&vi=1000494
Old Oct 8, 2012 | 01:17 PM
That's not what I need bro. Ignition switch is intact and it works fine.
The car turns on and everything, i just need to replace what's broken in the picture so that the steering wheel can lock again. Anyone have any idea?
Old Oct 8, 2012 | 01:26 PM
DeCePtEgRa's Avatar
Check rockauto.com enter your vehicle info then ignition starter switch or here is part number AIRTEX / WELLS Part # 1S6368 $199.79........if its broken it needs to be replaced or install a after market push button?????
Old Oct 8, 2012 | 03:27 PM
wtf_is_jdm's Avatar
I think he may be talking about the steering wheel lock? For future reference, it always helps to take that picture and put it into paint and draw a circle or an arrow to whats broken. Good luck bud.
Old Oct 8, 2012 | 04:23 PM
JuicedUpRice's Avatar
is it what your key goes into?its the ignition lock cylinder.
Old Oct 8, 2012 | 05:47 PM
Nicolai's Avatar
the arms that reach around the steering column on the ignition switch housing are broken off, get a new housing and put your guts into it.
check a junkyard or dismantler for the housing
Old Oct 8, 2012 | 06:59 PM
kchungb17a's Avatar
Year and trim please. The parts diagrams I've referenced assume that this is a 95 GSR.
I'm guessing that since this was an attempted theft that the cylinder itself is ruined? If by chance it is not, then as Nicolai suggested, you can just get the pieces that reattach it to the steering column. In the diagram below, you need #3 (x2) for sure and maybe #4 if you don't have this or it is damaged:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
If your cylinder is damaged you will need to get #2 from the above diagram. 2 things to consider: The cylinder will come with a new key. You can get it rekeyed to your original key if you want. Locksmiths charge about $40 for this. If not, you will have a 2 key car. The other is that if you have an immobilizer ('00-'01 I believe, but I did not see it in your photo), this part will cost about $100 more.
GL
Old Oct 9, 2012 | 12:14 PM
3rdtimecharmer's Avatar
10 Year Member
get a better alarm/ security. thats how you fix it
Barf Hat
Oct 9, 2019 05:45 AM
76 camaro car
May 28, 2011 12:40 PM
Un0Turb0-WP
Oct 19, 2004 11:45 AM
EricUSC
Nov 1, 2003 09:38 PM
