Questions about wire tuck in EF hatch
Old Oct 8, 2012 | 11:40 AM
Quencin's Avatar
Default Questions about wire tuck in EF hatch
Hey guys thanks for having a quite look, I am going to do a wire tuck in my EF hatch with my ZC swap, I found a great thread im going off of, but i was wounding after i cut the wires and re run them threw my fenders, what are the wires recommended to extended the wires? any info helps. thanks guys.
Old Oct 8, 2012 | 07:46 PM
swordofdoom's Avatar
Default Re: Wires.
Do not re-run them through the fenders and through the side of the door. That is a pi55ed poor way to re-wire things to and from your engine bay to the cabin. There is a rubber black plug close to the firewall that is next to the engine harness. Unplug that plug and use it to reroute wires.
Old Oct 8, 2012 | 10:32 PM
crx_si-r's Avatar
Default Re: Wires.
so your saying to tuck your engine bay wiring, move the harness over to the next opening? wouldnt that still leave your wiring in the bay?
Old Oct 8, 2012 | 10:58 PM
stackedhouse's Avatar
Default Re: Wires.
Yeah my wire tuck didn't go through the door.... But I just went to pick an pull and chopped off both headlight harnesses as far back as possible... Only had to make one solder per wire
Old Oct 9, 2012 | 12:56 AM
DCRB's Avatar
Default Re: Wires.
this........... is genius. why the f didn't i think of that?? probably looks tons cleaner too eh? i spent hours and hours extending my wiring :/.
Old Oct 9, 2012 | 06:56 AM
Quencin's Avatar
Default Re: Wires.
Well thats the things, I have a thread im going off, and he does not cut any new holes just uses the factory holes, and i have all the things i need, just wanted to know what are the wires i would nee to extended them as in the size of wires i would need? This is where imgetting my tuck info from. and thanks for any info guys. sure helps.
thanks guys.
http://importsnc.com/forums/car-tech...-150-pics.html
Old Oct 9, 2012 | 06:57 AM
crx_si-r's Avatar
Default Re: Wires.
thats how i did it, but i got it all from headlights to cabin harness.this way i could reuse the factory grommet for the engine harness and not cut up one. instead of soldering i connected the 2 harnesses with connectors.
Old Oct 9, 2012 | 07:09 AM
crx_si-r's Avatar
Default Re: Wires.
thanks guys.
why would you need to cut any holes? all tucks i have seen use existing holes.
Old Oct 9, 2012 | 08:40 AM
Quencin's Avatar
Default Re: Wires.
I dont need to, I know people that have cut new holes and have gotten a nicer cleaner tuck. i dont want to do that, i just want to figure out what gauge wires i will need.
Old Oct 9, 2012 | 09:26 PM
Default Re: Wires.
I'm just saying not to run it pass the doors unless you feel like crushing your wires. By all means its your car do whatever you like
Old Oct 9, 2012 | 09:37 PM
crx_si-r's Avatar
Default Re: Wires.
ummmm. how would they get "Crushed" as you put it? when there is already wiring going through that spot from factory that doesnt get "Crushed?"
Old Oct 10, 2012 | 12:05 AM
DCRB's Avatar
Default Re: Wires.
o/p i ran my wires exactly how that write up shows two years ago and to this day i have had zero issues with it.
i will say running the wires is much easier with the dash out of the car
Old Oct 10, 2012 | 06:35 AM
Quencin's Avatar
Default Re: Wires.
Really? got any photos? i foudn that link and it seems pretty good, so i was going to go off of that.
i dont want to cut new holes, would reather use the factory holes. and just buy wires that i can use to extend them.
could i do it with dash still in?
thanks guys.
Old Oct 10, 2012 | 07:04 AM
crx_si-r's Avatar
Default Re: Questions about wire tuck in EF hatch
I did mine with everything still I stalled. Just gets a lil crammed. Take your time and you will be fine
Old Oct 10, 2012 | 04:42 PM
Quencin's Avatar
Ummm what wires did you you use to extended them? Like what gauage and stuff? Ill make s thread if i get the right wires before the snow comes
Old Oct 12, 2012 | 06:09 AM
Quencin's Avatar
Im just looking for the type of wires i would need to use to extened my wires. thanks for helping.
Old Oct 12, 2012 | 01:28 PM
wickedEFguy's Avatar
I used 12 gauge when I did mine, I also found some 90-91EX door gromets at the junkyard, and ran everything through the door jams like this.
These pics isn't the finished product, but it was during the whole process when I did my tuck to give you an idea.
Old Oct 12, 2012 | 02:47 PM
crx_si-r's Avatar
12g seems kinda big to me. When I make a harness I use 20g Teflon wires.
90Attack
13
Oct 19, 2011 02:56 PM
coreysef
19
Jan 25, 2010 08:11 AM
stevieturbos
Jan 6, 2010 05:37 AM
jdmEF8racer
Oct 21, 2006 11:13 AM
CRXDrew
May 21, 2005 09:42 PM
