1990 sedan problems
the car is all stock motor wise bothing done to it it started by the hids turning off out of no where while driving had to turn light switch off then back on the battery light will come like in acc mode but wouldnt die when parked the corner lights turn on but the switch will be completely off but hey wont turn back off than the last thing is now it keeps blowing the ecu fuse when you turn to acc mode anybody have any idea what it could be or what i can do to it ?
thanks
thanks
The lack of punctuation is killing my comprehension.
Are you saying the car ran fine, but after the HIDs were installed then it started to go downhill with problems?
If so, disconnect the HIDs and see if the problems go away.
Provide a detailed diagram for how they are wired.
moleodonuts
Sep 13, 2005 02:00 PM
