Removing stubbern o-ring seals
Old Oct 7, 2012 | 07:16 PM
95-EX's Avatar
Icon2 Removing stubbern o-ring seals
My VC gasket has been leaking so I bought a Fel-Pro kit. I tried to remove the spark plug tube seals but ended up tearing them; I think they are the original seals. So now I have a VC gasket job I couldn't finish.
Does anyone know of a sure fire way to remove these seals? I tried to pry them out with a flat head screwdriver and a pick - No Luck.
Is there some chemical I can try, I want to get my car back on the road.
P.S. should I use some RTV Blue on the edges or is that not necessary?
Thanks
Old Oct 7, 2012 | 07:29 PM
doctorbee's Avatar
Default Re: Removing stubbern o-ring seals
wow they must have been baked on. try:
1. dental pick
2. rubber disolving solvents - i think acetone works
3. burning it off with a torch.
Old Oct 7, 2012 | 07:31 PM
Hidenplanvew's Avatar
its just rubber, you can burn it out if you want.. Razor blade w/e...
You just need the RTV/honda bond the corners where the cam sits
Old Oct 8, 2012 | 03:34 AM
djkurious's Avatar
Burn them off with a torch.
Old Oct 8, 2012 | 03:46 AM
forted's Avatar
I you take a pair of needle nose pliers sometime you can grab an end of the gasket and twist the gasket around the pair of pliers.
Old Oct 31, 2012 | 07:48 PM
95-EX's Avatar
It turns out that I mistakenly removed them the wrong way. Best way in to take a flat head and tap them out with hammer - gently and the whole piece will come out. The guy at the parts store also learned this for the first time. Thanks to another customer there who told us both how it should be done.
--Wasted a lot of time trying to remove what I thought was a baked on seal.
TravisBiggie
Jun 7, 2012 02:27 PM
DC206R
Apr 1, 2009 11:41 AM
janz3n
May 13, 2006 09:47 AM
boosted ek
Jun 27, 2005 07:01 PM
SuicideSlide
Oct 2, 2004 08:57 AM
