OBD0 D and B series distributor the same?
Old Oct 7, 2012 | 02:53 PM
ThePizzaMan's Avatar
Default OBD0 D and B series distributor the same?
I have a new-ish B series dizzy and an original 1990 on my CRX... I used the cap, and everything else seems to look the same... I just need to transfer the plugs as my B dizzy has no plugs on it.
Will it work?
Old Oct 9, 2012 | 10:43 AM
Default Re: OBD0 D and B series distributor the same?
Bummmmp!
Old Oct 11, 2012 | 11:26 AM
Nobody knows? Everything sure looks the same internally. Guess I'll have to swap it over and see what happens.
Old Oct 12, 2012 | 08:07 AM
HondaPartsHero's Avatar
Technical Hero
What do you mean "newish? What year did it come off of? Obd0 and obd1/2 distributors have different parts inside and can't be swapped (minus the coil and igniter in some cases).
Old Oct 12, 2012 | 10:18 AM
Dizzy from a OBD0 B series... looks the same as the OBD0 D dizzy in my stock CRX. Newish as in hardly used, so I wanted to put it in the CRX.
Thanks
Old Oct 12, 2012 | 09:31 PM
f@sth@tch89's Avatar
If my memory serves me correct, the holes want all line up. I believe on my first b-series swap years ago I had to fire the car up with an 88-91SI dizzy. I believe it will work, but it has been so long ago.
Old Oct 13, 2012 | 04:11 AM
Technical Hero
Yeah holes don't line up
Old Oct 13, 2012 | 03:17 PM
Ah okay thanks... What about internal components... Igniter/Coil the same? Looks to be...
Old Oct 13, 2012 | 03:40 PM
Technical Hero
Yes
smellmyface
May 29, 2007 10:44 AM
Fallen86
Feb 15, 2006 08:53 PM
