s300 tables
Old Oct 7, 2012 | 10:29 AM
SPOOLINmatt's Avatar
Default s300 tables
IF i get some cams that delete the vtAk lobe or even if i locked the vtec rocker into action, would i just from then on out tune the "low speed" tables in s300? and never touch the high speed?
Old Oct 7, 2012 | 11:42 AM
ThE HeLLRaZoR's Avatar
Default Re: s300 tables
I would think you'd have to re-tune the entire range! As that will change your entire Torque Curve. Your going to be using differant Sites then the Normal Old path at WOT.
I have never Tuned a Car, that is just my opinion. GL to U with it though...
Old Oct 7, 2012 | 07:19 PM
im fully aware of all of that, i tune my own car at the track. just didn't know if it from then on out is tuned from one table instead of both tables still for some reason i dont know.
Old Oct 7, 2012 | 08:01 PM
mtber's Avatar
The easiest way is to use the low cam table only.
Edit the rpm index as needed for higher rpm resolution.
97CWITR
Mar 29, 2009 07:01 PM
vtecmissle
Acura TSX
Jun 22, 2006 10:07 AM
rice is nice
Aug 27, 2005 03:07 PM
H22CL
Mar 26, 2005 03:11 PM
JDM00SI
Sep 17, 2004 04:25 AM
