License plate screw holes
I have a 2007 CR-V. I had to replace my license plate and I was unscrewing the bolts and broke both of the bolt heads off. One of them broke off inside the screw hole. The other is still sticking out about .25 in. Any ideas on how to fix this?
Pictures as requested:
http://s1320.photobucket.com/albums/...ps22bfdeca.jpg
http://s1320.photobucket.com/albums/...ps395f0555.jpg
The first is the picture of the hole where the bolt broke off inside. I tried using a bolt extractor but I think I messed it up even more. The second is the bolt that is sticking out still.
kinda hard to see...but, if you cant pull it out from the outside...
you might wanna take the panel off (plastic inside) then see if if the end of the bolt/screw is long enough for you to turn, to go thru the hole... i dont know if you get what im saying..
spidermancivic
Aug 11, 2007 08:17 AM
BIG RICH
Apr 7, 2004 05:14 AM
