degreeing non vtec cams
Hey guys just a quick question i gotta ask, I have a cam degree kit i borrowed from my neighbor but there is no way to mount the dial indicator with this particular setup, is there a special setup required to degree the non vtec head, anyone got any pics of this? Also where exactly do you position the dial indicator on the cam/rocker.
Can you affix a steel L bracket where the power steering bracket is held, same with the upper JRSC belt tensioner? Use a mag base and go from there.
All this smack talk you do to people and you have no clue how to degree a set of cams? Ohh, this is too rich!!! Obviously you don't put the dial indicator on the rocker OR camshaft. The valve spring retainer is acceptable because you are trying to measure lift at the valve. As for the mounting point, just like on a VTEC head without the proper fixture, make a sturdy "shelf" for it to sit on.
OK, remove that threaded stud what's in-between the cam gear's and see what the thread is. Unscrew the mounting shaft out of the starrets magnetic base and see what the thread is. If you are as lucky as me they will be the same... if not purchase a cheap stand, remove the shaft and weld a bolt with the required thread to the bottom of it so you can screw it into the head.
1sikhatch
May 13, 2007 04:37 PM
