Somebody help a playa
Whats up my name is rufus are you good with honda rebuilds, im having some problems..
NEw items:
-Starter
-Distributor(tested good) button and cap replaced just in case
-spark plugs and wires
-checked all fuel lines
-new battery
brother had the harmonic balanced replaced and afterwards havent been able to get it cranked alot of people tell me that the timing is off but my brother had the timing checked top and bottom and it still wont completely crank, it literally sounds like its about to crank but wont turn over, i was going to spray some injector cleaner in it tried it with my explorer one time and burned off my eyebrows can you help me out with some tips..
Everybody says its the timing, the timing is good had it checked to many times and i know its not electrical because it wouldnt turn over at all, could one set of plugs not be getting fire, i checked them and there are wet but the distrubator is good with new button and cap wtf????
NEw items:
-Starter
-new battery
playa, start with the basics
1. make sure the spark plugs are sparking
2. make sure there's gas - there a special starting fluid you can buy and pour into the intake so you don't burn your eyebrows. if it runs for a bit with the fluid then you know it's not getting enough gas
junya16
Mar 1, 2003 05:41 PM
