Injectors are not spraying obd0 b16 crx
Old Oct 4, 2012 | 08:34 PM
crxmadness's Avatar
Default Injectors are not spraying obd0 b16 crx
Back story:
I stored my obd0 b16 crx 4 years ago and everything worked fine when stored.
Tried to start it today and I have:
compression
spark
2 clicks from main relay
no check engine lights
fuel to fuel rail
The problem:
0 injectors are spraying. I am reading 12 volts at the injector. Since I have a resistor box I think I should be getting 5 or so volts to the injectors when the key is in the on position. Is that correct?
What are some common fixes associated with this problem? I use to know all this stuff years ago when I was building my crx but now it is all foreign to me.
Old Oct 4, 2012 | 09:01 PM
Former User's Avatar
Default Re: Injectors are not spraying obd0 b16 crx
Have you measured the fuel pressure?
Maybe your injectors are clogged from sitting so long.
With the key in ON(II), do they click if you ground the injector ground wire?
Old Oct 4, 2012 | 09:09 PM
crxmadness's Avatar
1) I have a fuel pressure gauge on my fuel rail, so yes I have enough fuel pressure
2) All 4 injectors could be clogged, but I figured that is pretty rare because at least one would trickle something
3) I will go ground them and report back.
Old Oct 4, 2012 | 09:17 PM
crxmadness's Avatar
Yes they all click when grounded and my fuel pressure dropped to zero each time I grounded one of them. At least we know they are not clogged and they work. What does this result tell you?
Old Oct 4, 2012 | 09:23 PM
Unplug ECU connector A. In the connector, terminals A2, A4, A16, and A18 should have continuity to body ground. Do they?
Old Oct 4, 2012 | 09:36 PM
crxmadness's Avatar
They all came up between .5 - .7 (200 setting on ohm meter)
Old Oct 4, 2012 | 09:42 PM
Check continuity between each fuel injector clip and the ECU (1=A1; 2=A3; 3=A5; 4=A7).
Old Oct 4, 2012 | 09:49 PM
crxmadness's Avatar
not sure if I am doing this right, but this is what I did:
1 lead on A1 and other lead on A3 and so on for each of them I got 16.1 reading
1 lead on A1 other lead grounded ohm meter didn't change.
Old Oct 4, 2012 | 09:53 PM
Unplug all injectors and ECU connector A. Ground the ground wire in each injector clip to the engine. Then measure continuity to body ground individually at A1, A3, A5, and A7 in the ECU connector.
If all terminals have continuity to body ground, then swap in a known good ECU to see if the engine fires up and runs.
Old Oct 4, 2012 | 10:09 PM
crxmadness's Avatar
The all came back between .3 - .5 (200 setting)
Old Oct 4, 2012 | 10:48 PM
crxmadness's Avatar
Dang, I plugged in my spare ecu and she fired right up. Thank you .
MastaFlyMason
Sep 3, 2017 10:06 AM
646EG
Jan 22, 2008 05:12 PM
turboxsi
Apr 17, 2005 04:15 PM
crazyrex
May 4, 2004 08:30 PM
EGHatchy
Jul 14, 2002 11:25 AM
