Please help with rattling noise
Old Oct 4, 2012 | 07:10 PM
civic_duty23's Avatar
Default Please help with rattling noise
Hello all,
I am trying to understand a noise that is coming from my 2000 honda civic. There is a rattling noise best described as one that is like touching the tip of a pen on the moving blades of a plastic desk fan when it is powered on. It is only intermittent and goes away on its own after a minute or so, or if I turn off the fan using the A/C ****. However the rattling increases as I accelerate and decreases when decelerating, so it is not a consistent volume. This is the best I can do to describe it without taking a recording, and any help on what to check would be appreciated. I plan to see if there is something in the blower fan, but I am not sure if that is even the problem.
Thanks
Old Oct 4, 2012 | 09:01 PM
ElementzofR's Avatar
Default Re: Please help with rattling noise
Something probably caught in your fan maybe?
Old Oct 4, 2012 | 09:03 PM
dirty19's Avatar
Ridin Dirty in Cali
leaves or sticks find their way in there on ocasion.
Old Oct 4, 2012 | 10:14 PM
slomofo's Avatar
GDD Member
How's your oil level?
Does it make this sound while turning?
Does it ever make the noise when the fans are off?
Old Oct 5, 2012 | 05:20 PM
Thanks for the replies.
I just had a complete fluid replacement , oil change and other preventative maintenance done about a month ago. Today during driving, I have now ruled out the fan as being the problem, because there is no sound when the fan is on without the A/C being on. When I press the A/C button to turn it on, the sound starts for a few moments before going away, or until I turn off the fan. What could be the broken part? Also there is no sound when the fans are off. Thanks.
Old Oct 6, 2012 | 09:45 AM
Well I took it to the mechanic and it has been diagnosed as a broken compressor. I am debating whether to buy the parts and do it myself (although i have no experience) or take it to the shop for labor. Any recommendations for a good compressor? I am thinking of getting this one:
http://www.ebay.com/itm/BRAND-NEW-A-...101b45&vxp=mtr
Are there ones manufactured by Honda (OEM)?
Old Oct 6, 2012 | 09:58 AM
Former User's Avatar
If you don't have experience with A/C or car work, then you are best off paying a professional.
In brief, the job entails:
  • Recovering of the refrigerant
  • Removing compressor
  • Flushing system of debris generated by failed compressor
  • Installing new compressor with new oil and receiver/dryer
  • Placing the system under a deep vacuum
  • Leak testing system
  • Recharging with proper volume of oil and weight of refrigerant
sinine
Honda CR-V & Element
Dec 1, 2011 11:32 PM
mfisher1967
Honda Civic (2006 - 2015)
Aug 21, 2007 08:52 PM
Mike1486
Dec 15, 2004 05:49 PM
99lude
Nov 19, 2003 07:10 PM
