PGM-fi delete
Old Oct 4, 2012 | 06:03 PM
boostedteg4dr's Avatar
Default PGM-fi delete
95 civic.
Im looking to delete my pgm-fi. what pins at the ecu need power constant, key on engine running, key on engine off?
Basically what pins need 12v for ecu to work? what pins need to be grounded?
Old Oct 4, 2012 | 06:17 PM
90civicstdgold's Avatar
Default Re: PGM-fi delete
why?
Old Oct 5, 2012 | 02:24 PM
please only post if you know how to do this.
Old Oct 5, 2012 | 03:39 PM
v4lu3s's Avatar
RTFM
are you running carbs now or something?
usually to delete pgm fi you can just take the ecu out since that is the system there.
Old Oct 5, 2012 | 04:46 PM
grumblemarc's Avatar
The Grumpiest
Public forum guy. If you expect YOUR questions to be answered then you need to ANSWER some as well.
Old Oct 6, 2012 | 12:59 PM
no carbs. doctors orders.
Old Oct 6, 2012 | 02:21 PM
hybridmiklo's Avatar
remove pgmfi? sure, remove intake manifold and all wiring associated with the ecu. there you go. next question please
Old Oct 9, 2012 | 07:47 PM
Just picked up a wire diagram. Ill keep the pgm-fi. ill probably need it. ha
Techy
Apr 22, 2007 02:32 AM
Hegster
Mar 20, 2007 12:04 AM
jvonb
Mar 1, 2006 04:37 PM
Rich93DS
Oct 9, 2005 07:46 PM
