is fuel level in a 4th gen vtec prelude regulated by pressure or floating sensor?
Old Oct 4, 2012 | 05:59 PM
97accordbuildlx's Avatar
Default is fuel level in a 4th gen vtec prelude regulated by pressure or floating sensor?
how exactly is it regulated? i recently took off the head and also disconnected the fuel lines. the gas tank was pretty emtpy. i just filled it up with 4 gallons and its still reading empty. the digital sensor on the dash was reading fine before the rebuild so i doubt i went bad. is pressure involved? do i need to rebuild pressure in the gas line or is the sensor in the tank stuck? all in all after the rebuild ive only ran it a good twenty minutes. at idle.
Old Oct 5, 2012 | 03:56 AM
pentaq's Avatar
Default Re: is fuel level in a 4th gen vtec prelude regulated by pressure or floating sensor?
It's a floating sensor.
Old Oct 5, 2012 | 12:21 PM
u think the sensor in the tank went bad? are there any wire clips/plugins in the engine bay that relate to the fuel sensor?
baruba
May 24, 2014 01:53 PM
sony224422
Jun 17, 2011 05:08 PM
xelloss
Oct 22, 2008 12:12 PM
