shift light to open slot in cluster
Old Oct 4, 2012 | 12:23 PM
FWDrifter559's Avatar
Default shift light to open slot in cluster
i was wondering if anyone knew how to install a shift light into the open spot in the cluster by where the check engine light is. just wondering if it can be done or not. if so, is their a writeup on how to install it?
Old Oct 4, 2012 | 06:18 PM
njn63's Avatar
Default Re: shift light to open slot in cluster
RPM activated switch hooked to a light bulb.
Example of switch: http://www.summitracing.com/parts/SUM-830450-1/
There's also ways to do it with certain ECU's but that's way more complicated than you're probably looking for.
Old Oct 4, 2012 | 06:27 PM
uberEFtuner's Avatar
Yes it can be done. I did it with my radar detector warning light. First you have to sand off the black paint on the clear plastic. Then install the light. I used an led and an old pen tube to make it a spot light. Otherwise it lit everything up. I used a blue LED and it was very noticeable.
As far as the electronics for the shift light you will have to buy something.
Old Oct 5, 2012 | 07:46 PM
crazyboy's Avatar
sorry to threadjack but its kinda on subject but what aboutr using that rpm activator for vtec?
Old Oct 6, 2012 | 04:54 AM
njn63's Avatar
It's been done but you won't have the computer adding fuel for the change in cam.
northemt88
12
Nov 27, 2007 08:09 PM
HondamanXxX
25
May 31, 2007 09:53 AM
EK79
May 21, 2006 01:19 PM
slayersluck
Mar 7, 2005 04:28 PM
quik2kSi
Dec 19, 2003 08:47 AM
