engine idle went nuts
Old Oct 17, 2002 | 11:33 AM
Hcivic88's Avatar
Default engine idle went nuts
alright, my idles been really weird lately
at idle, the engine speed is constantly going up and down, itll be normal, speed up for about 2 seconds, then it sounds almost like it bogging
I figured it might be a vaccum leak or something, but usually when theres a vaccum leak, doesnt the idle stay high, not pulse back and forth??
I checked for codes and I'm not getting any,
anybody got any ideas i should check out??
thanx everyone
Old Oct 17, 2002 | 01:25 PM
didyouhearthat's Avatar
Default Re: engine idle went nuts (Hcivic88)
I'd like to know too. I have same problem. I heard vacuum. But don't know for sure.
Old Oct 17, 2002 | 01:42 PM
Malgerus's Avatar
My D16Y8 was doing this... I think it may be the 02 sensor, like the sensor is giving the wrong signal to the computer and the ECU tries to compensate. My car was doing the same thing, then it threw an oxygen content code (2 days before I crashed it )
BTW, Joeyb: NO'MAAM forever!!!! Married with children ownz
[Modified by 89_Y_49RIP, 10:42 PM 10/17/2002]
Old Oct 17, 2002 | 02:00 PM
Booger's_Rex's Avatar
Default Re: engine idle went nuts (89_Y_49RIP)
if you need to check for a vaccuum leak get yourself some carburator cleaner and spray it were it could be leaking. it works beautifully. found many of my leaks when my car was doing the same thing.
Old Oct 17, 2002 | 02:45 PM
Urban Business
Guest
Posts: n/a
definatly not o2 sensor. map sensor could have taken a ****, evac could have as well. or vacume leak, lines, *gaskets* etc
Old Oct 17, 2002 | 04:11 PM
Tee Jay's Avatar
Default Re: engine idle went nuts (TorteX)
Mine does it too, it goes vroom psssttt vroom psssttt vroom pssttt.
Just a little demonstration. Sometimes it's normal, but that's rare
Old Oct 17, 2002 | 04:12 PM
Tee Jay's Avatar
Default Re: engine idle went nuts (CrX_HF)
One more thing, how do you change your avatar? I can't seem to figure it out!
Old Oct 17, 2002 | 04:40 PM
Hcivic88's Avatar
alright, thanks everyone for your help, i guess ill check around for leaks first, spray some carb cleaner on my vaccum lines and see what happens
and yes it sound a lot like "vroom...pssttt....vroom...pssst", sounds just like that
and i dont think u can change your avatar while you're a trial member, you gotta wait till you're a full member
beocop
Jul 2, 2017 05:19 AM
Nisif
Nov 26, 2011 07:22 PM
Redprelude98
20
Jul 14, 2009 03:33 PM
em1gangsta
Jan 26, 2008 03:40 PM
beef-cake
Jun 7, 2007 12:57 PM
