Pedal Install Questions - Dumb and Easy Stuff
Old Oct 17, 2002 | 11:25 AM
Chris N's Avatar
Default Pedal Install Questions - Dumb and Easy Stuff
Ok. So I got my OMP 1000's in the mail yesterday.
I'm pretty clueless when it comes to stuff like pedals. Here are some assumptions I have made about installing these pedals. Let me know if I'm on the right track or not, or any suggestions you have.
I assume this is a 2/3 beer process. And...
1. You take the stock rubber pedal covers off. Are they even covers?
2. Drill holes into the metal pedal (that sounds funny....) under the rubber.
3. Bolt pedals down tightly.
4. Drive car with new pedals and drink more .
Old Oct 17, 2002 | 11:28 AM
Nate B's Avatar
Default Re: Pedal Install Questions - Dumb and Easy Stuff (1107)
Old Oct 17, 2002 | 11:30 AM
Flux's Avatar
you got it. Just make sure that there is room for the nut on the other side fo the pedal before you drill the hole...
JPP's Avatar
JPP
That is pretty much it. Altough you should not drink and drive...
Try to position the new pedals to improve your heel /toe technique if you which.
Old Oct 17, 2002 | 11:39 AM
Chris N's Avatar
Default Re: Pedal Install Questions - Dumb and Easy Stuff (JPP)
I assumed you guys knew I wasn't driving drunk....
Although with my we-todd mechanic skills, I may have to just keep drinking after installation and drive much, much later on, maybe even just wait till the next day!
Old Oct 17, 2002 | 11:40 AM
Nate B's Avatar
glad I could help Chris
Old Oct 17, 2002 | 11:47 AM
BlackAckeR's Avatar
Default Re: Pedal Install Questions - Dumb and Easy Stuff (TypeR#1111)
Don't forget your dremel tool... My OMP's didn't cover the metal pads fully, so I had to grind and grind and... ...turned out to be a 6 pack job, but they look and feel great!
Old Oct 17, 2002 | 11:49 AM
Chris N's Avatar
Default Re: Pedal Install Questions - Dumb and Easy Stuff (BlackAckeR)
Mine look like they ought to cover with no problem... I hope so, I have no dremel and NO dremel experience!!
FJO3's Avatar
I installed the same pedals about 2 months ago. They're pretty easy, just be careful when drilling the pedal for the gas pedal. I only put one screw in that one because there isn't really room to drill another and it fits snugly with just one, but more power to you if you can get both in there. The other two pedals were a breeze!
Old Oct 17, 2002 | 08:53 PM
Chris N's Avatar
Default Re: Pedal Install Questions - Dumb and Easy Stuff (2000R#1355)
After a second look, the actual 'pedal' seems to be plastic. Well, at least not some sort of steel/metal. Can anyone confirm this? If so, any regular drill bit would do the trick.
Old Oct 17, 2002 | 09:12 PM
Phoenix_ITR's Avatar
in order to get the plastic cover off the gas pedal, pry the top off with a pair of pliers and then just slide the cover down and off. that's probably the most annoying part of the whole install...
tony
Old Oct 18, 2002 | 06:12 AM
Jack Black's Avatar
You must be talking about the gas pedal. There's a hard plastic cover over a formed sheet metal backing. There's a little tab at the top of the cover that you can pry up with a screwdriver and slide it down and off. I took my entire gas pedal out to put my cover on. It was easy enough to get out, just unhook the cable from the top, unhook the return spring, straighten and remove the cotter pin from the pivot (don't loose those little washers!). Getting it back in was kind of a PITA -- getting the return spring back on was a bitch.
Old Oct 18, 2002 | 06:18 AM
Hooch'n's Avatar
Default Re: Pedal Install Questions - Dumb and Easy Stuff (itr01-0851)
It's easier then you think, just do it.
CIVIC dude
Honda Civic (2006 - 2015)
18
Apr 2, 2007 07:04 AM
WWDTrackRacer
Apr 1, 2006 07:51 AM
Teh_Oven
13
Mar 27, 2004 08:21 AM
Racer X
Jun 17, 2003 08:52 AM
lucas569
Mar 4, 2002 09:58 AM
