96 GSR Suspesion
Old Oct 3, 2012 | 02:59 PM
Solidis's Avatar
Default 96 GSR Suspesion
Hey Guys .. I need to change my suspension.. reason being when i go on the Highway or street and i hit a small dip even if i slow down .. my tires will hit the inside walls of the teggy and it smells like burn tire .. what suspension should i go with.. Any suggestions
Old Oct 3, 2012 | 03:52 PM
skipper28-DC's Avatar
Default Re: 96 GSR Suspesion
I had the same issue, with tokico oem replacments I decided to go Eibach lowering springs.-1.7 inch drop on fatFives. Now I almost never rub, although the drop is still too low for my preference.
Also, tire size is a concern if you dont want your fender liners to shred. I believe Im on 195 tire size.
Old Oct 3, 2012 | 09:12 PM
Solidis's Avatar
Im new to the hole Suspension thing.. whats the diffrence in coil over shocks .. etc
Old Oct 4, 2012 | 12:26 AM
bnetkillzone's Avatar
Pretty much two ways. Lowering springs: simply swap the springs out
Adjustable coil over is basically the same spring Is sitting on a collar that can be spun up or down to adjust the ride height.
Old Oct 4, 2012 | 12:29 AM
Solidis's Avatar
Does that also help in the stiffness in the car. like i hit a bumb will i still feel the whole "bump" or will i sorta feel it.. i just wat my teggy to feel more stiff not so jumpy
Old Oct 4, 2012 | 12:00 PM
Stiffness is entirely different. Stiffness has to do with spring rates and dampening.
Old Oct 4, 2012 | 12:13 PM
3rdtimecharmer's Avatar
10 Year Member
just buy coilover sleeves and a good set of shocks.
a lot of people like to do the ground control coilover sleeves with tokico blue shocks. look into it. has a good street ride feel.
i myself like the more aggressive ride for track. all depends what u want
also is your name in reference to MGS series. if so, cool. MGS zero is gonna be the ****.
metal gear vengence is bullshit
Old Oct 4, 2012 | 01:50 PM
Solidis's Avatar
Yes Actually it is a MGS Name.. haha.. Been playing it since Nes...
Old Oct 4, 2012 | 06:11 PM
10 Year Member
nice. but you do know that the nes and SNES have no play in the original story line. it was made in USA just for $$$. not an actual hideo kojima project. i love MGS myself.
back to topic. good luck with your search. suspension is a serious thing, to me that is. right now im running ground control coilover with illumina white shocks. looking in getting full coilovers soon after my swap is done.
Old Oct 4, 2012 | 07:51 PM
90_EX_Civic's Avatar
read this thread, it'll help you start in your look
https://honda-tech.com/forums/suspension-brakes-54/click-here-all-you-curious-about-suspension-setups-their-costs-reliability-2967499/
Old Oct 8, 2012 | 01:02 AM
Solidis's Avatar
https://honda-tech.com/forums/showthread.php?t=2967499
awsome bro thanks
averscds
Dec 10, 2018 02:46 PM
1sickek187
May 13, 2010 07:45 AM
100miles+
Honda Civic (2006 - 2015)
Mar 11, 2008 07:18 PM
carrnut21
Mar 30, 2007 01:30 PM
yellow blur
May 12, 2003 03:49 PM
