What's up with 99 Accord Engine Malfunction Light at 48K
Old Oct 17, 2002 | 11:17 AM
duder's Avatar
Default What's up with 99 Accord Engine Malfunction Light at 48K
Curious about Engine Malfunction Light coming on at 48,000 miles. Manual says to check gas cap (and tighten), if light doesn't go out after 3 trips, take it to the dealer. I can't afford to take it in to the dealer right now. Car runs great. So what is the point of this light? Will changing air filter or pvc valve fix it?
Old Oct 17, 2002 | 11:22 AM
RotaryBzzz's Avatar
Default Re: What's up with 99 Accord Engine Malfunction Light at 48K (duder)
emissions related. Triggered an OBD II response. Gas cap related codes might fall under emission related hardward...which might still be covered under a Federal mandated Honda emmision-control warranty. Call the dealer and ask about it and if it would cover what's going on. It might just be a defective rubber o-ring in the gas cap...
Old Oct 18, 2002 | 05:42 AM
jweller's Avatar
Default Re: What's up with 99 Accord Engine Malfunction Light at 48K (RotaryBzzz)
How to Read Your Check Engine Light
post up what code it is throwing. I can look it up for you. or google for honda check engine codes. they are all over the web.
Old Oct 18, 2002 | 05:48 AM
Accord94DX's Avatar
Bring it in. It will be free. There is an extended emissions warrenty, you will either get one of the 3 following procedures done:
Phase 1: Clear codes, nothing more.
Phase 2: Replace secondary O2 sensor and clear codes.
Phase 3: Replace Catalytic Converter, Secondary o2 sensor, and clear codes.
Old Oct 18, 2002 | 02:05 PM
duder's Avatar
Default Re: What's up with 99 Accord Engine Malfunction Light at 48K (jweller)
Thanks for responses. Code looks to be either 9 or 90, not sure because I only get 9 long flashes.
Old Oct 18, 2002 | 04:09 PM
Chiovnidca's Avatar
Code 90. Make sure your gas cap is in good condition and tight. Pull the backup fuse in the underhood fusebox for ten seconds to clear the light. It may take a couple drive cycles to see if it recodes.
Old Oct 18, 2002 | 05:04 PM
jweller's Avatar
Default Re: What's up with 99 Accord Engine Malfunction Light at 48K (Chiovnidca)
what he said, except pull fuse #13 in the passenger side fusebox.
Old Oct 18, 2002 | 05:37 PM
Chiovnidca's Avatar
Good eye.
specbb6
Jun 5, 2012 02:50 AM
Accord-Guy
Mar 12, 2009 06:37 PM
mooneybeams
Aug 20, 2008 06:36 PM
96AccordEX
Jul 13, 2006 09:40 AM
CivicT
Apr 11, 2002 04:16 AM
