Organizing material
Old Oct 2, 2012 | 09:13 PM
HickamHatch's Avatar
Default Organizing material
Trying to figure out a good way to get this tubing out of the corner of the shop. Anyone have good ideas on how to organize this mess? I want it off of the floor
Old Oct 3, 2012 | 12:58 AM
xXSanderXx's Avatar
Default Re: Organizing material
intresting topic
Old Oct 3, 2012 | 06:01 AM
AdReNaLiN's Avatar
Interested to see how you organise bends etc.
Straight tube can be stored on shelving.
Old Oct 3, 2012 | 06:54 AM
Bends are easy, just throw them in a box on a shelf and label what size they are. The aluminum 180's and 90's that are wrapped in the foam can easily just set on each other and don't need to be boxed up. I don't want the 4' long straights taking up shelf space that I don't have. Looking for an easy way to see exactly what I have.
Old Oct 3, 2012 | 08:27 AM
g230sport's Avatar
What about an old oil drum or something? A place i worked had one for steel and aluminum
Old Oct 3, 2012 | 08:30 AM
that-guy's Avatar
i have seen in several steel/iron shops, that they either weld about two pieces of 18" tubing to a wall (if your using a steel building) at about a 15* angle, far enough apart where your typical tubing length will set on it, or using chain or another strong material to hang from the rafters to suspend it. that way it stays out of the way, and you can still use the space underneith of it if you need to
Old Oct 3, 2012 | 09:02 AM
SovXietday's Avatar
I would build a way to store it the way that Lowes or Home depot store there plywood/ long PVC tubing.
Like this, only considerably smaller. 3 arms with 2' spacing, couple of levels for sch10, thinwall stainless, thinwall AL, random, all done.
Old Oct 9, 2012 | 09:30 AM
vtechjunkie's Avatar
I like the upright idea actually. Even if you did have to lift it off the ground, to clean under it. Makes for a much more efficient use of space.
Old Oct 9, 2012 | 04:14 PM
CRMB's Avatar
OG Fabricator
Pidgeon hole racking in the prefered method for storing partial bundles or less of straight material.
http://www.dexion.com/Global/Constru...ck55_large.jpg
Cantilever racking is the prefered method for bundled quantities of straight materials
http://www.e-rackonline.com/product_images/47.jpg
Pallet Racking is the prefered method for storing bends.
http://www.sjf.com/rack/teardrop_pallet_rack.jpg
We inventory 300,000 bends, and around 40,000 feet of tubing. We do this with a combination of the 3.
Old Oct 9, 2012 | 09:11 PM
redboost10's Avatar
^^^ive emailed you and pmed you on here with no response, called with no answer too. still in business?
Old Oct 10, 2012 | 02:53 PM
CRMB's Avatar
OG Fabricator
I pm'd you back. Please pm me the # and email you were contacting us from. The sales guys are super busy but they are required to call back any missed calls and return all emails.
Old Oct 12, 2012 | 12:38 PM
I think I am going to build something that hang from the ceiling of a section in the back of the shop for the straight. That way it is off of the floor and I can easily see what I have since it will be laying down flat.
Old Sep 5, 2014 | 11:39 AM
Finally came up with something
Old Sep 7, 2014 | 10:42 PM
sdr KEL's Avatar
that took 2 years?? lol jk
nice
Old Sep 9, 2014 | 02:36 PM
FaceTuned's Avatar
Lol
Old Sep 10, 2014 | 12:41 PM
v8killaz's Avatar
lolol
Instead of tkaing up room on the wall id mount it higher, unless you use that stuff everyday.
Old Sep 10, 2014 | 04:11 PM
redboost10's Avatar
We use something with the same design except it's about 30 feet long and floor mounted. Just a large rack that has about 6 different shelf levels for different diameter/material.
b00stedbyFastrax
Welding / Fabrication
Mar 16, 2009 06:21 AM
arcboy
22
May 1, 2007 06:44 PM
CooBlueDAB
13
Feb 9, 2005 11:20 AM
hulkhb
Jul 25, 2004 12:13 AM
RevenantAE
Jul 1, 2004 07:18 PM
