Timing Belt Troubles after 500 miles
Old Oct 2, 2012 | 07:36 PM
934thgenLude's Avatar
Default Timing Belt Troubles after 500 miles
Hey guys, I just joined the proud family of prelude owners a couple of weeks ago, and to play it safe, seeing that the H23 is an interference engine, I went ahead and did a full timing belt change (timing belt, balance belt, tensioners and water pump). After about 500 miles, i started to hear like a whistling or faint whining sound under the timing cover. So when i removed it to take a look, i found the belts to have faded lines in between the teeth. Is this normal? Are the belts on waaayy too tight? Any help is appreciated. I have a picture also to help explain. You can see it here. https://i.imgur.com/5I2MB.jpg
Old Oct 3, 2012 | 07:51 AM
bigblue7t6's Avatar
Default Re: Timing Belt Troubles after 500 miles
How tight is your belt? I know its hard to describe over the internet but in my experience a whining belt is usually the result of a belt that has too much tension. Also, did you go with a Honda belt or aftermarket?
Old Oct 3, 2012 | 10:39 AM
I think i might have over tensioned it, that was my first guess. The balance belt felt a little loose so i thin i adjusted it a little more than what the instructions said. It will push down when i push on the belt, but it won't come up enough to come off the gears. Also the belts are aftermarket.
Old Oct 3, 2012 | 02:01 PM
yroachy's Avatar
I'd try resetting the belt tension and see if it went away.
Old Oct 3, 2012 | 06:20 PM
Alright, so i got the tension reset, did a few rev's so and the belts seem to sit fine and not walk. My only concern now is that the balance belt feels a little loose. Is it normal for the balance belt to feel looser than the timing belt???
Old Oct 3, 2012 | 07:16 PM
ZekeComa's Avatar
You should get a belt tension meter to tell if it's within spec or not. That's what I recommend you getting. Better safe than sorry.
Old Oct 3, 2012 | 09:22 PM
97accordbuildlx's Avatar
yea usually wine=too tight/new belt.
Old Oct 4, 2012 | 06:25 AM
Acidcrakker's Avatar
IMO I would just toss the balancer shaft belts.
Old Oct 4, 2012 | 10:03 AM
yroachy's Avatar
Yes it's normally more loose that the tbelt. There is very little Rotaional resistance spinning the balance shafts, making it less likely to skip teeth... Tbelts have a lot of force to deal with so they are normally tighter.
+1 on removing the bs belt..
Old Oct 4, 2012 | 06:41 PM
Okay, i did the job, the whining went away, but now it's having other problems.... I went to start it and it started, but then the engine would almost stall out after reving it. Could this be a sign that I'm off timing at all????
Old Oct 5, 2012 | 12:59 AM
holmesnmanny's Avatar
Yes.
Old Oct 7, 2012 | 04:08 PM
Alright. Well, turned out it was off timing a bit, but i also noticed, (funny story right here), that i forgot to install the dipstick tube. I did some research and found that not having it installed, can cause symptoms vacuum leaks, which could also help with the fact that it was stalling. So, i got the timing readjusted, REINSTALLED the dipstick tube, put it back together, and it finally runs smoothly without any whining sounds. Thanks guys for the help!
polymerman
Honda Civic (2006 - 2015)
Jan 15, 2014 04:05 PM
chahsiubow
Dec 14, 2007 10:01 PM
Imprezn
May 6, 2003 01:36 PM
obd2gsr
Dec 21, 2002 08:53 PM
