po6 ecu acting up please help
hello ppl ive recently got a ek 4door and swap the engine to a lsvtec i'm running a obd1 po6 ecu and peaches a moates chip kit also a vtec kit.so i install them and loded up a b16 base map frome crome so i burrnd the chip and put it in my ecu and my car is boging and runing like **** no vtech and is verry slow thanks for your help
k so i pull the cell codes out and came out code 17 vss which the speedo works fine also than the other code is tricky i don't know if its 41 or 3 and 11 but it goes like this __ __ __ __ _ but on crome disable
the knock sensor disable eld atmospheric pressure sensor disable injector test circuit disable oxygen sensor (open loop) vtec speed check also vtec temp check . thank you guys for the reply
k so i reburned the chip to a stock p72 know its idling funny the cell code is solid and when i try to retrieve codes it stays solid i'm also hearing a really strong buzzing sound coming from the manifold so disconnected the (iacv)''intake air control valve sensor it stop buzzing so im assuming thats the problem
k so i took your guys advice and went out and got a bone stock ecu i plug it in and i get code clear code 41 02 sensor but it bogs and turns off don't know what to think know =( any other ideas ? i will check the timing does anyone know what psi should fuel should be at ? thanks for your response
by hart and location
