H22 transmission problem
Old Oct 2, 2012 | 07:29 PM
gnxpro24's Avatar
Default H22 transmission problem
Just picked up a base 97 Prelude today. Transmission said to have been replaced with a 55k JDM tiptronic one. If I rev or run the engine remotely hard it spews fluid and it drips at and idle. Its dripping right where the two pieces of the trans case go together. Do I just drop the transmission and reseal the two pieces together with RTV? Or is this something more serious than a seal leak?
Old Oct 2, 2012 | 07:42 PM
yroachy's Avatar
Default Re: H22 transmission problem
You didnt notice this on your test drive before you bought it?
Old Oct 2, 2012 | 07:49 PM
gnxpro24's Avatar
No sir I did not. That is beside the point now. I want the car and am not returning it so I just need to know the best approach to fix it
Old Oct 3, 2012 | 02:56 AM
yroachy's Avatar
Pull the trans and trace the leak. The helms manual will have instructions and tips on how to do this.
Old Oct 4, 2012 | 08:15 PM
Hidenplanvew's Avatar
bet its rear main seal
Old Oct 4, 2012 | 08:33 PM
yroachy's Avatar
I'd bet on the seals to the torque converter if it's leaking tranny fluid between the block and bell housing.... Chances are they fucked it up when they did the swap.
Old Oct 4, 2012 | 10:43 PM
gnxpro24's Avatar
Its not leaking between block and bell housing, its leaking where the two pieces of the transmission case are sealed together. It wouldnt be the rear main either because that would be oil not transmission fluid
Old Oct 5, 2012 | 12:43 PM
veebutt's Avatar
your best bet is to ask people who have this chassis on a site that specializes in this chassis. like preludepower or preludezone.
Old Oct 6, 2012 | 09:24 AM
HAHA I guess thats what I get for "drinking and writing" my bad I didnt read it all the way
Old Oct 6, 2012 | 04:46 PM
yroachy's Avatar
In that case get the Helms out and pull apart the tranny to reseal it. Check to see if you can get a used one cheaply might be easier than pulling apart an automatic.
Hopefully it's smooth sailing with your freshly acquired lude once you get this fixed.
Old Oct 6, 2012 | 08:10 PM
Actually honda auto's are very easy to pull apart, I think they are easier then a manual... But they are both very similar
Old Oct 7, 2012 | 05:41 PM
gnxpro24's Avatar
I dont feel like messing with another transmission...this is the second Honda Ive gotten in 6 months that needs an auto trans and an alternator. For the first time Im sending it to the shop on Thursday
Old Oct 11, 2012 | 08:48 AM
Waxaz420's Avatar
Consult the God of Helms... he shall show you the way... Trannys are pretty easy to bust out take it out take it apart and put it back together... I understand this is not the exact same tranny but this might help you as far as the tear-down...
Waxaz420's Avatar
Bumpin song too...
Old Oct 11, 2012 | 08:51 AM
gnxpro24's Avatar
Automatics are a whole different level of difficulty than manuals
pigeonman67
May 9, 2010 05:32 PM
lude98SH
Jul 22, 2007 07:12 AM
h22_guy
Dec 15, 2006 12:51 PM
Sam5
Feb 29, 2004 05:41 PM
