Gsr question
Old Oct 2, 2012 | 06:34 PM
James4537's Avatar
Default Gsr question
I have a full civic gsr swapped car and I'm looking to drive 14 hours to visit my girlfriend every once in a while. Is it safe bringing this car idling at 4 grand on the way there at about 80mph?
Old Oct 2, 2012 | 06:40 PM
10psiLsEf2's Avatar
Default Re: Gsr question
if your engine doesnt over heat,good tires,brakes..... etc etc. i dont see a problem man.
Old Oct 2, 2012 | 06:46 PM
Fliptard's Avatar
naa, you'll be fine. I drove mine to VA from pa/ny.... 9 hour trip any mine was all good. I even overheated mine ALOT cause I had a coolant leak that I could NOT find and it was 100* + the whole way...
Old Oct 2, 2012 | 07:19 PM
BC_Garage's Avatar
It shouldn't be a problem. I've seen people daily drive built B18c1s before.
Old Oct 2, 2012 | 08:00 PM
TEGDFORLIFE's Avatar
A maintained motor shouldn't have a problem. If it's been a while since your last oil change you might wanna do it beforehand, or at the very least make sure your oil level is fine.
Old Oct 2, 2012 | 08:20 PM
furious94ls's Avatar
Check and change any fluids before hand. Bring some oil and honda coolant with you just in case. These motors are very strong. It will be very happy cruising at 80mph.
Old Oct 2, 2012 | 10:53 PM
dickdragon's Avatar
If u have a stock dash cluster of the lowest model in your civic, danger zone isn't till 7k rpm at least. Sure, you'll be just fine.
BioRex437
Aug 14, 2017 02:31 PM
hAtChBaCkFoReVeR
Nov 12, 2008 12:01 PM
GSR15
Nov 2, 2007 10:28 AM
Robstunner4
Mar 7, 2005 05:03 PM
