need help!!! after replacin the distributor it wont start it just cranks
Old Oct 2, 2012 | 11:48 AM
93lude99swap's Avatar
Default need help!!! after replacin the distributor it wont start it just cranks
I have a 93 prelude wit a 99 engine swap my distributor went bad I took out the old one and replaced it wit a new one but now it wont start. I didnt move anything don't understand what I did wrong please help
Old Oct 2, 2012 | 11:49 AM
Default Re: need help!!! after replacin the distributor it wont start it just cranks
My engine is h22a4
Old Oct 2, 2012 | 03:00 PM
yroachy's Avatar
Did you replace it with the right dizzy? Obd1 and 2 h22 dizzys are different. How is your car wired? Obd1 or 2?
Old Oct 2, 2012 | 03:46 PM
Obd2 yes its the correct one. They both look alike but the internal modules r different they obd 1 only has 2 modules the obd 2 has 3 modules the new one its identical to the old one
Old Oct 2, 2012 | 03:58 PM
yroachy's Avatar
I'd be leaning to a defective dizzy if that is the only thing you touched.
Old Oct 2, 2012 | 04:06 PM
Is there any possibility my timmin might b off?
Old Oct 2, 2012 | 04:35 PM
yroachy's Avatar
It should still start, the slot is offset on the cam so it should be impossible to put it in 180 degrees out. And rotating the dizzy only gives a limited amout of asvance/retard and it should run max/min anyways. Try rotating it to see if it starts and check for spark... If nothing, try running it with your old dizzy. What was wrong with your old one?
Old Oct 2, 2012 | 04:59 PM
snobordboy's Avatar
Moderator
And the age old question, are the wires on in the right sequence?
Old Oct 2, 2012 | 08:07 PM
The wires are on sequence and on my old one the shaft came loose so it messed up my rotor and cap
Old Oct 3, 2012 | 02:57 AM
yroachy's Avatar
Spark?
Old Oct 3, 2012 | 05:26 AM
Spark is there Its confusing I dont understand what could be wrong
Old Oct 3, 2012 | 12:33 PM
yroachy's Avatar
Ya it's not making much sense. Double check your wire sequence. Was it running fine before you swapped the old one?
Old Oct 3, 2012 | 01:08 PM
Yes it was running fine until the old one broke and the car died on me towed it home swaped it and nutin
Old Oct 3, 2012 | 01:36 PM
yroachy's Avatar
Pull it off and check the condition of the notch in the cam.
Old Oct 3, 2012 | 03:05 PM
I did that it.seems fine only thing I can think of is defective dizzy I already went and ordered another one hopefully dat will b the problem
Old Oct 3, 2012 | 03:12 PM
crazes's Avatar
Moderator
make sure that your contacts on the rotor are good. Plus make sure that the dis is spinning properly
Old Oct 4, 2012 | 12:20 AM
Cap and Rotor are new and it seems to b spinning properly
holmesnmanny's Avatar
Did you plug the connectors in ?.......all the way ?
Old Oct 4, 2012 | 03:13 AM
Yup double.checked that and also replace the ignition coil I thought that might be it but nutin
Old Oct 4, 2012 | 07:32 AM
crazes's Avatar
Moderator
ok if your getting spark and the gears are aligned correctly the only things left are fuel and air. Are you getting fuel into the system at all and also is your tb working and giving enough air to the car
Old Oct 4, 2012 | 09:52 AM
The tb works fine I have gas. How do I check if the gears are aligned? I don't think they moved since I didn't move any thing other than the dizzy
Old Oct 4, 2012 | 12:56 PM
crazes's Avatar
Moderator
on the cam gears you have to lines 1 on each gear. those should be aligned together when they come around to top dead center.
What I meant by fuel is that if your getting fuel into the system or ie pressure
Old Oct 4, 2012 | 01:35 PM
Do you have to align the gears everytime u change the dizzy?
Yes I get fuel in the system
Old Oct 4, 2012 | 01:54 PM
Acidcrakker's Avatar
Are you even sure that the dizzy was your original problem to begin with
Old Oct 4, 2012 | 05:52 PM
Yes the shaft on the dizzy came loose I don't know how but it was girndin inside the dizzy
vaderman_x
Jun 9, 2019 07:00 AM
Mikes95eg
Jul 10, 2013 10:55 PM
egtony
10
Sep 4, 2009 01:44 PM
peeka
Mar 31, 2009 02:45 PM
javiergt02
15
Aug 21, 2006 07:37 PM
