99 civic ex coupe 5spd idling high
Old Oct 1, 2012 | 09:37 PM
GRNcivEX's Avatar
Default 99 civic ex coupe 5spd idling high
Hello,
I'm new to the forum and to owning Hondas. Just bought it, have a few bugs to work out, suggestions/personal experience would be appreciated.
I have a stock 99 civic ex coupe 5spd.
When I'm braking or coasting the engine idles at 1500 rpm.
When I come to a complete stop it still idles at 1500 for a few seconds then drops to about 700 rpm.
When I first start the car it idles at 2000 and drops down between 1500 and 1000rpm after a few minutes.
Also the CEL is not lit
I searched around some other threads and it seems like it could be the IACV, although my RPMs don't bounce from low to high the way most describe.
The previous owner said he cleaned the IACV, but Id have to do it myself before I could rule that out as the problem.
Has anyone else experienced this problem or know what might cause it?
Old Oct 3, 2012 | 09:40 AM
R8198EJ8's Avatar
Default Re: 99 civic ex coupe 5spd idling high
Yes IACV would do that. Other possible causes are the throttle cable, throttle body, or it just needs an idle speed adjustment.
Old Oct 3, 2012 | 09:42 AM
R8198EJ8's Avatar
While you're at it, see if it is throwing any codes.
ChelseaJean
May 9, 2015 08:20 PM
Hmotoredcoupe
Apr 14, 2013 07:41 PM
Sniffle
Oct 15, 2008 10:47 AM
spoonraker
Honda Civic (2001 - 2005)
26
Apr 5, 2008 03:56 AM
