Transmission slipping from high gears to low
Old Oct 1, 2012 | 05:53 AM
panotski's Avatar
Default Transmission slipping from high gears to low
1996 Honda Civic Ex, 2 Door Coupe, Automatic
Whenever the car is shifting down from a higher gear (slowing down), I feel that the shift comes a second too late and usually accompanies some sort of "strong nudge" or something. I don't know how to describe it, but there is definitely something wrong.
As I said, this almost always happens when I'm slowing down (i.e. stop signs, freeway exits, etc). No problem when shifting up, though.
Old Oct 1, 2012 | 11:34 AM
jbpnoman's Avatar
Default Re: Transmission slipping from high gears to low
When was the last time your transmission fluid was replaced?
Old Oct 1, 2012 | 11:47 AM
strategy400's Avatar
I'd rather have shifting issues than slipping issues...
Check the level. #1 thing with auto trans is correct fluid level. #2 is fluid type/quality.
If the level is good flush the tranny fluid it takes ~10 quarts to completely flush the fluid (about ~$80-90 at the Honda dealer). Use only genuine Honda fluid.
Read my post in the thread below:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/do-i-need-replace-my-auto-tranny-fluid-3088061/
If no improvement check throttle/kickdown cable adjustment and motor mounts.
Old Oct 1, 2012 | 12:42 PM
furious94ls's Avatar
It's probably the torque converter. Check the fluid condition.
jhammermil2008
Feb 25, 2017 06:27 PM
jmanuel
Apr 24, 2014 09:48 PM
poland accord
Oct 22, 2008 11:57 AM
redline32
Nov 27, 2007 04:33 AM
globy123
Dec 17, 2006 07:20 PM
