Transmission slipping from high gears to low
1996 Honda Civic Ex, 2 Door Coupe, Automatic
Whenever the car is shifting down from a higher gear (slowing down), I feel that the shift comes a second too late and usually accompanies some sort of "strong nudge" or something. I don't know how to describe it, but there is definitely something wrong.
As I said, this almost always happens when I'm slowing down (i.e. stop signs, freeway exits, etc). No problem when shifting up, though.
Re: Transmission slipping from high gears to low
I'd rather have shifting issues than slipping issues...
Check the level. #1 thing with auto trans is correct fluid level. #2 is fluid type/quality.
If the level is good flush the tranny fluid it takes ~10 quarts to completely flush the fluid (about ~$80-90 at the Honda dealer). Use only genuine Honda fluid.
Read my post in the thread below:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/do-i-need-replace-my-auto-tranny-fluid-3088061/
If no improvement check throttle/kickdown cable adjustment and motor mounts.
