01 auto integra blown engine - b20 replacement?
Old Oct 1, 2012 | 01:47 AM
AccordBoy88's Avatar
Default 01 auto integra blown engine - b20 replacement?
so my car just engine blown so now i need a new engine.
what would i need to swap it out for a b20
do i need to change the ecu, sensors or anything or can i just drop it in.
Old Oct 1, 2012 | 05:04 AM
el crapitan's Avatar
Default Re: 01 auto integra blown engine - b20 replacement?
how did you come to the conclusion that the engine "blew"?
if you're getting a b20, try and get the b20z. both b20b and b20z will drop right in. use the engine harness from the b20, if it's not cut. you can use your original distributor and ECM
Old Oct 1, 2012 | 06:28 AM
kyden's Avatar
you cannot use a crv engine harness in an integra. the integra one will all plug in said b20. a b20 (us spec) will be a drop in. a jdm one will need a ckf bypass if you decide to use an obd2 ecu.
kush_1
Mar 21, 2011 06:49 AM
EFinawesomeman
Jul 30, 2007 07:18 PM
XYU
Oct 31, 2005 03:45 PM
go2sleep
Apr 23, 2005 07:17 PM
SOHCam
Jun 1, 2002 02:44 AM
