EF converting to obd1 using high impedance injectors
Old Sep 30, 2012 | 06:41 PM
da9blk1's Avatar
Default EF converting to obd1 using high impedance injectors
Ok, converting my EF to obd1 with a p28, rywire ecu jumper harness and distriutor harness.
i may be using high impendance injectors with my build.
what happens to the resistor box?
what do i need to do to get the injectors to work with my set up.
thank you!
Old Sep 30, 2012 | 08:54 PM
da9blk1's Avatar
Default Re: EF converting to obd1 using high impedance injectors
help
Old Sep 30, 2012 | 08:57 PM
RanCRX's Avatar
Once you go obd1, you switch to obd1 injectors eliminating the need for the resistor box. only obd0 injectors needed them. Thats as far as I know.
Old Oct 1, 2012 | 05:05 AM
da9blk1's Avatar
Yes I understand that. But on the obd0 harness don't the injectors run tto the resistor box?
Old Oct 1, 2012 | 07:22 AM
artiecubz's Avatar
I know I read about this some where in here.
Found this on the Rywire's site. Hope it helps.
http://www.rywire.com/catalog/images...0to1jumper.gif
Old Oct 1, 2012 | 10:22 AM
da9blk1's Avatar
That 8 pin grey plug is for the distributor correct?
Old Oct 1, 2012 | 10:25 AM
artiecubz's Avatar
If you're talking about the plug in the pics, he's referencing the the injectors.
Old Oct 1, 2012 | 12:27 PM
v4lu3s's Avatar
RTFM
if you HAVE to switch injectors (for what reason?) you remove the resistor and splice the wires together. Personally I left my obd0 injectors in with the resistor pack.
Old Oct 1, 2012 | 02:00 PM
RadioRaccoon's Avatar
+1 ^^^^
beansandrice
Aug 28, 2009 07:32 PM
lilsicsoul
Mar 1, 2009 04:23 AM
swartz
Apr 7, 2005 04:16 PM
TheHatchHog
19
Oct 18, 2004 09:25 PM
Deetz
Sep 17, 2003 05:11 PM
