Flywheel Bad or good Pics inside
Old Sep 30, 2012 | 04:39 PM
b20bFourDoorCivicLX's Avatar
Default Flywheel Bad or good Pics inside
said i might want it, it was laying around he believes its a stage 3 ,
how does it look is it worth keeping
Old Sep 30, 2012 | 07:39 PM
97accordbuildlx's Avatar
Default Re: Flywheel Bad or good Pics inside
thats not even a flywheel..........................
the CLUTCH looks like it has some meat on it still.
youll need the pressure plate and the flywheel to run this on your car. also youll need to make sure it will work with your engine. ALSO, get your flywheel machined before you throw it on your car. if your clutch is fine though dont throw a used clutch in your car, especially a 6puck with STOCK HP. all its going to do is put more strain on your transmission then youll have to end up replacing your tranny. id take ti for like 25 bucks or something no more.
Old Sep 30, 2012 | 07:50 PM
woops.....not the greatest mechanic but good advice,ill just get rid of it
Old Oct 1, 2012 | 12:05 AM
dont sweat it we all have to learn sometime
Old Oct 4, 2012 | 05:55 PM
dc2LS's Avatar
I'd skip on that one if your gonna replace your clutch might as well put a new one in there.Yea a previously stated that's the clutch disc not flywheel .You still need a pressure plate and grow oh bearing.
Old Oct 4, 2012 | 09:14 PM
CRX_Control's Avatar
thats garbage , get a oem exedy replacement for around 100 bucks on ebay. Comes with pressure plate ,clutch, pilot bearing and throwout bearing, cant beat that!
Old Oct 4, 2012 | 09:27 PM
it is garbarge, believe me thATs why its in the trash, my cars mostly stock besides basic bolt ons, straight pipe, suspension but when i go lsv when i get enough funds ill buy a stage 2 clutch, i got a 1 month old stock clutch in right now, new everything so ill be good for awile
blazin99si
Transmission & Drivetrain
May 30, 2012 07:53 PM
Turbo Dan
10
Jun 28, 2006 03:12 PM
DarkDragon
Aug 3, 2005 11:07 AM
paulzy
Oct 17, 2001 11:43 PM
