AEM Twin Fire 30-2821
Old Sep 29, 2012 | 08:57 PM
ThE HeLLRaZoR's Avatar
Default AEM Twin Fire 30-2821
Can someone please answer this Question;
WHAT DOES THE LITTLE RED LIGHT ON THE SIDE OF THE BOX DO??? Is this Light suppose to; Light up, Blink, or do NOTHING?
On there Technical Features, they say the LED is "Ignition Trigger Indicator".
I have Fuel, I have Spark, (LED does NOTHING)the Engine will NOT start(not even Caugh)!
The motor is in Excellent condition 180 in all 4. I'm 100% sure my Wiring is Correct.
I think the problem is the Spark is so Weak, the Plugs are IMMEDIATELY Fouled out
Old Oct 1, 2012 | 07:55 AM
Rtype16's Avatar
Default Re: AEM Twin Fire 30-2821
what computer are you using to trigger the twin fire?
Old Oct 1, 2012 | 12:19 PM
xenocron's Avatar
The light should light up when the box is making a spark. If the spark isnt hot enough, it wont light that light.
In the atmosphere, that weak spark will light easily as there is no pressure. In the cylinder, there is compression and pressure and it wont be able to bridge the gap...no boom
Old Oct 1, 2012 | 03:13 PM
AEM EMS 30-1050
I grounded the Twin Fire to a Clean Chassis location and power is from the Alternator, as the Battery is located in the back Seat area...
Could this ground location be a problem? MUST it be Grounded at the Battery?
Old Oct 1, 2012 | 04:12 PM
Default Re: AEM Twin Fire 30-2821 FIXED! bad Ground!
So I decided to Ghetto Rig a bunch of Wires together and Grounded the Twin Fire to the Battery(in the Back Seat area)LED IS NOW Flashing! Another Demon solved-on to the next! Thanks for the help!
Old Oct 7, 2014 | 12:19 PM
tablecivic's Avatar
ignition on the red light should be constantly on no flash ... now i changed my ground after i blew the 15amp fuse to the constant 12v. now the red light dims off,and the fuse doesn't blow. anyone have a idea on what is going on ? im trying to sync the timing but im not going to start the engine with the twin fire like this. ... constant 12v and ground is directly to the battery now
civc12
Honda Civic (2001 - 2005)
Aug 9, 2020 02:06 PM
cksnah252
Engine Management and Tuning
13
Oct 16, 2015 09:47 AM
clean
Jan 18, 2003 07:50 AM
