91 DX hatch only holds six gallons of gas?
Old Sep 29, 2012 | 09:15 AM
jdmeg6118's Avatar
Default 91 DX hatch only holds six gallons of gas?
I bought this Civic and it runs out of gas at about half a tank, ran out of gas in it.
Checked fuel pump and tank everthing is fine, anything else i can check?
91 DX 5-speed all stock.
Old Sep 29, 2012 | 09:41 AM
alex14's Avatar
Default Re: 91 DX hatch only holds six gallons of gas?
Mine does it too. i think the sock/filter fell off of my pump.
Old Sep 29, 2012 | 05:43 PM
t-town_ep's Avatar
Are you sure you checked the fuel pump and tank properly? Because I'm almost 100% sure your fuel sock either fell off or broke. Drop the tank again and pull the fuel pump to make the sock is on it. If the sock is on the pump, make sure its the correct one.
Part # fs121 made by airtex. I bought mine from advanced auto. O
Old Sep 29, 2012 | 10:11 PM
jdmeg6118's Avatar
Thank you I'll double check, could it have anything to do with the evap system?
Old Sep 30, 2012 | 12:57 AM
DCRB's Avatar
nope. if you're running out of gas at half of a tank your sock isn't on correctly or your tank is half full of sludge/rust/sand. the evap system is removable, i merely have a hose running from the vent tube on the fire wall to down under the car, no issues.
Roy Leyva
Sep 7, 2017 06:32 AM
Dnizzle
11
Feb 10, 2013 07:40 PM
FJBB6
Oct 12, 2009 05:35 PM
Msnier85
Apr 9, 2007 04:24 PM
kaoss_11
11
Dec 9, 2004 08:29 PM
