Faulty Igniter Symptoms?
Old Sep 29, 2012 | 07:36 AM
Telecatster's Avatar
Default Faulty Igniter Symptoms?
1998 Civic EX coupe (D16Y8) with MT, 124K miles. No problems starting. No issues shutting off after car warms up. No CEL codes.
Engine runs well with the exception of what feels like an electrical related. minor misfire.Idles well and rpm's are not fluctuating. Wires/plugs/cap/rotor/ all in good shape and less than a year old. Spark test is blue but not bright white on all cylinders. Good fuel pressure too.
I've read a lot of post here and elsewhere about faulty and completely broken
igniters, and it seems there's quite a range of symptoms before they finally stop working and a car will not start. the slight misfire feeling becomes more noticeable at higher speeds. Also, car should be getting better MPG's
Best ways to test? Am I on the right tracking pin-pointing the igniter? Anyone with similar experience.
Old Sep 29, 2012 | 08:40 AM
Former User's Avatar
Default Re: Faulty Igniter Symptoms?
Weak spark is generally a coil problem. Ohm test it.
CEL codes?
RedEJTwo
May 9, 2015 01:11 PM
Crazed_GSR
Jul 13, 2013 04:43 AM
Sonnboy18
Aug 14, 2009 05:25 PM
Jorsher
Jul 21, 2006 09:55 AM
Phat Corolla
Jan 2, 2005 10:30 PM
