Honda CR-V & Element 2WD & 4WD Element & CR-V
Part# for 97-01 Input shaft bearings(inner/outer) and seals
Old Sep 28, 2012 | 05:22 PM
shermanyang's Avatar
Default Part# for 97-01 Input shaft bearings(inner/outer) and seals
Wondering if anyone knows what the Honda OEM part numbers are for these items? I went to the Honda dealer today and the dumb *** sitting behind the counter refused to look it up for me. Said I would have to find the part number and get back to him. Seriously? Isn't that his job?
Anyway, if anyone can find the part numbers for these online for me I'd greatly appreciate it. Also, has anyone ever replaced the inner/outer input shaft bearing before and once you have the tranny torn apart what else should I replace while I'm in there?
Old Sep 28, 2012 | 05:57 PM
94EG8's Avatar
Seagull Management
Default Re: Part# for 97-01 Input shaft bearings(inner/outer) and seals
Automatic or 5 speed?
And yes that is their job. If it was me I would have complained.
Old Sep 28, 2012 | 07:11 PM
This is the 2nd time that ******* has told me this. The last time I asked him for rear sway bar bushings and he told me the same exact thing. What a punk! Anyway, it's a 5 speed.
Old Sep 29, 2012 | 03:37 AM
LDForget's Avatar
when you need part numbers go to http://www.hondaautomotiveparts.com/
Old Oct 1, 2012 | 06:54 PM
I'm not 100% sure since it doesn't identify it as "input shaft bearing" so tell me if this is correct...I'm thinking it's #18 in this picture correct?
Old Oct 2, 2012 | 02:09 AM
94EG8's Avatar
Seagull Management
there's no number 18 in that picture...
You want numbers 8 and 11.
Old Oct 2, 2012 | 10:34 AM
LOL! Thanks 94EG8, it was a long day yesterday lol. Ok...so I've got the inner input shaft bearing, now it's time to find the outter bearing...
Old Oct 2, 2012 | 12:44 PM
94EG8's Avatar
Seagull Management
Outer bearing: 91004-PX5-008 BEARING, BALL (28X78X20)
It's listed under mainshaft.
AdReNaLiN
Oct 16, 2008 08:51 PM
B16CRXT
Aug 27, 2008 06:25 AM
drbenne
Jan 16, 2008 05:15 AM
DeDonDeRosa
Dec 14, 2005 08:33 AM
Pengo
Jun 20, 2003 08:52 PM
