what gear oil
Old Sep 28, 2012 | 09:13 AM
williamgasdick's Avatar
Default what gear oil
I am doing my swap And was wondering which oil mix to use and where to get it from? T2w4 tranny going in my prelude ?
Old Sep 28, 2012 | 10:51 AM
afrotec's Avatar
Default Re: what gear oil
Honda MTF
Old Sep 28, 2012 | 12:29 PM
theBB1er's Avatar
Originally Posted by afrotec
Honda MTF
this. honda man's trans = use honda MTF only unless your trans has very worn syncros.
in one of my cars someone used conventional motor oil previously and shifted terribly, swapped it for honda MTF and it shifts like knife through butter now. other car which was poorly maintained and when draining trans fluid it had the consistency of dirty water. put honda MTF in and same great results.
Old Sep 28, 2012 | 01:44 PM
bigblue7t6's Avatar
Honda MTF FTW!
Old Sep 29, 2012 | 11:05 AM
snobordboy's Avatar
Moderator
What they said^ stick with stock fluid if the trans. is stock. If you go to aftermarket gears, syncros, LSD, or final drive, then look at different fluids.
Old Sep 29, 2012 | 11:21 AM
How much does the trans hold ?
Old Sep 29, 2012 | 01:02 PM
bigblue7t6's Avatar
Iirc it is right at 2 quarts for what you can get out of it for a drain and fill with the trans in the car, empty (as in new install) is like 3.5 i think
Old Sep 29, 2012 | 01:27 PM
prelude1897's Avatar
I use Honda, but I've also added some Lucas tranny fluid as well, and so far it seems to be holding up just fine
jaidedeye
20
Feb 24, 2013 05:35 PM
TravisCadello
52
Apr 15, 2009 02:47 PM
irollerblade
Mar 22, 2009 10:43 PM
zx2gotboost
11
Feb 19, 2006 09:20 PM
G-reX
11
Mar 19, 2003 08:20 AM
