89 crx z6/y8
Old Sep 28, 2012 | 06:24 AM
Shawn_71288's Avatar
Icon6 89 crx z6/y8
Ok well once again I need help my crx is in a shop now and the results have not changed. The motor will start but still runs like it has a huge cam in it. They've done leak down test compression test and a lot more and everything checks out. It won't idle at a steady rate and has no power when u give it gas. Z6 bottom end with a y8 head adjustable cam gear wiring redone to match motor. No one can seem to get it running right. Any help or suggestions would greatly be appreciated. Thanks
Old Oct 18, 2012 | 07:12 PM
Default Re: 89 crx z6/y8
Results of leakdown test is less than 20%. Compression test cylinder
1-195psi,2-198, 3-198, 4-200
Old Oct 18, 2012 | 07:15 PM
Any other test I should run or any help would be great thanks
Old Oct 19, 2012 | 04:22 PM
Sr420Det's Avatar
do u have the correct head studs installed, u need one z6 and the rest y8. Might have a lil leaky headgasket under running conditions. does it sound like its missing? pull the plug wires individually until one of them doesnt make a difference in how its running, this will single out the bad one
Old Oct 19, 2012 | 04:29 PM
Yeah I have the correct studs In place with the one y8 bolt. The leak down test is in the green and compression is also in the green
Old Oct 20, 2012 | 06:47 AM
Sr420Det's Avatar
its one z6 bolt, did u pull the individual plug wires one at a time? check ignition timing with a gun
bubbaparks2121
Apr 28, 2008 09:33 PM
zcrx2006
Nov 29, 2007 07:25 PM
huntarrr
Nov 17, 2005 04:02 PM
drjondurst
Jan 7, 2003 12:56 PM
LegendLS95
10
Oct 18, 2001 07:45 AM
