Honda Domani Turbo build
When I first got the car August last year. 1998 Honda Civic VTi M/T
Got a Domani front cut for my conversion. Started tearing the car.
Full Spec List
Exterior
OsakaJDM windshield visor (with Furukawa-san signature
) http://www.osaka-jdm.jp/Full Honda Domani/Isuzu Gemini Conversion
Craftsquare mirrors
Stage21/PVI customize cf front end
EK4 rear green backglass with wiper
EK4 ViRS window visors
Engine
ITR B18c5 Engine
Forged Pistons
Eagle Rods
Crower Valves/Valvesprings/Retainers
Garrett GT35r with Tial Housing
HP Racing Manifold
HP Racing Full Exhaust
Tial 44mm wastegate
Exedy Twinplate
Precision IC
Precision 1000cc injectors
HKS BOV
HKS camgears
HKS Mushroom filter
Circuit Hero Sparkplug Cover
Spoon Hi-Tension Wire (gen 2)
Aeromotive Fuel Pump
Neptune ECU (boost per gear)
Blox Radiator
Samco Hoses
Greddy Rad Cap
ITR Condenser
Interior
Full Orthia Conversion
K-tuned Bseries Shifter
ITR Gauge
Defi Gauges (Pressure, Oil, Boost)
Spoon SW
Dspec quick release
CTR Boot
Pioneer AVH 4450BT
Razo turbo timer
EK4 Factory Tweeters
Wheels & Suspension
Neova ad08 17
Neova ad08 16
Volk Rays SE37k 17x7.5
Volk Rays CE28 16x7.5
BBS RS 16x8.5 (stance)
Bridgestone VT-R 17x7.5
Wedsport tc05 16x8
Ohlins coilovers
Cusco front strutbar
AP Racing BBK
Glanz Rotors
ITR Brakes (rear)
Goodridge Brake Lines
STD trailing arm
BWR towhook
BWR Rear subframe brace
Spoon tiebar
Making 5++hp at the dyno :D
How she's now
You charlatan this is an Isuzu Gemini build!!
Kidding, kidding I know they're the same. Is that hood modified or is it built one piece like that? the scoop looks odd. What's the info on the internals of the motor? So clean so clean!
Engine Specs:
Forged Toyota Pistons (Fab)
Eagle Rods
Exedy Twin Plate
Stock Cams (B18C-R)
HKS Camgears
Thanks everyone for your inputs.
The hood isnt a zero pressure area, but putting a bigger scoop in the right way would of yielded you better results... Heat rises....
We see this all the time with boosted track cars.
Some like to raise up the hinges to get the back of the hood sitting a little higher, doesnt help much either, because the hood area near the windshield is a near zero pressure area.
Not much air moving there.
I cant identify the scoop you have, but Afterhours automotive in california makes the best honda hood duct systems out there.
Here is the scoop
https://honda-tech.com/forums/showth...ght=hood+scoop
Website for Afterhours.
http://afterhoursautomotive.com/
Here is the scoop
^^thanks. Nice touch on the hood scoop. I would do it like that if there's some shop here that does like that. The scoop is almost the same although the opening is in reverse since my scoop sits on top of the cf hood.
Keep in mind because you are boosted your temps will always be higher.
You'll have to invent more ways to cool.
Clean build, love it but that turbo is really laggy and TQ should be higher. You may want to look into a different turbo like a Silver Surfer or Reaper from TheShodan that will have much better response and a better TQ curve. Unless you wanted an all top end motor. It wants to keep making power too past 9K it looks like.
Get that Isuzu crap logo off the front of the grill.
