How long to wait between ATF changes when doing 3x3 flush trick?
Old Sep 27, 2012 | 01:16 PM
fragmare's Avatar
Default How long to wait between ATF changes when doing 3x3 flush trick?
About how many miles should I be driving in between changes when performing the 3x3 ATF flush? I have a 93 DX coupe, if that matters.
Old Sep 27, 2012 | 01:22 PM
10psiLsEf2's Avatar
Default Re: How long to wait between ATF changes when doing 3x3 flush trick?
3x3 atf trick? please explain
Old Sep 27, 2012 | 01:28 PM
mrspeedy69's Avatar
I think he's talking about where you drain it fill it, drive so many miles, then do it again so that after the 3rd time all of the old atf is no longer in there.
I did this about a year ago and I think I drove between 50-100 miles each time.
Old Sep 27, 2012 | 01:31 PM
10psiLsEf2's Avatar
oh ok i see! you wouldnt have to drive it too far IMO just Operating Temperature and drive it on the freeway through all gears to allow the different pressures to happen inside the tranny.
then drain and so forth
furious94ls's Avatar
I put the car on jack stands. After the drain/fill I run the car in every gear for one minute. Then I repeat. After the 3x3 a month later I drain and fill 1x. After that do it once a year and you should be good.
Old Sep 27, 2012 | 01:36 PM
fragmare's Avatar
Yea, that's what I'm talking about. I did my first of the three changes last week.
Old Sep 27, 2012 | 05:22 PM
redm3turbo's Avatar
The first time I did it...I drained, filled...waited a month...then again, and waited a month, and so forth. So a 3 month cycle.
I have a buddy is a Master Tech at honda and he says they do it....put the car on the lift... drop 3, lower car and fill, start car, row the gears 3-4 times. Raise car, drop 3, lower car, row gears 3x...etc.
So at honda (or at least his shop) its 0 miles, and a minute or so. Ive done both now personally. 3x3 with a few miles between, and 3x3 with nothing but throwing it in gear a few times. Both times it has work exactly the same. As long as you put it in gear I believe the ATF sloshes a round a bit and your good.
As long as your using quality ATF (pref Honda OEM) your good either way.
Old Sep 27, 2012 | 05:58 PM
10psiLsEf2's Avatar
THIS
Old Sep 27, 2012 | 07:07 PM
fragmare's Avatar
Awesome! So it's not going to screw up the process by driving around for a few weeks between changes. And, yea, I'm using genuine Honda ATF... Which is apparently all DW-1 these days.
Old Sep 27, 2012 | 07:56 PM
redm3turbo's Avatar
nope you wont hurt a thing.
youll be surprised at that magnetic drain plug though. it catches alot. Another thing --just my personal opinion here---you dont have to drop your atf very often unless your in extreme conditions. I am doing 30k now. drop 3 every 30k. dropping it yearly is a waste for me. I dont think I put enough miles on it yearly to warrant a drop. I think honda thinks its good for around 100k...
Old Sep 28, 2012 | 12:04 AM
fragmare's Avatar
I changed it about 3 months ago, but I used 3 quarts of Valvoline DexIII... before that, yea, it had been at least 100k miles, maybe a little more. Now that Honda is apparently switching everything over to DW-1, I'd feel better having only the DW-1 in there (since I'm not sure how that mixes with DexIII). That's mainly why I'm aiming to flush the tranny.
On a side note, I must say that after putting the 3 quarts of DW-1 in there, it already seems to shift smoother.
And, yea, that drain plug had a ton of shavings on it when I changed it 3 months ago. Almost nothing when I changed it last week, though.
Old Sep 28, 2012 | 07:23 PM
10psiLsEf2's Avatar
Although i will ad i have seen At start slipping after replacing the atf after 100k hondas especially.
Just make sure you use your year specific atf (they usually change gen by gen)
Old Sep 28, 2012 | 11:37 PM
fragmare's Avatar
I'd love to use Honda Dexron II, as specified in the manual, but Honda no longer offers that. Only their Honda DW-1 ATF.
08ReDevil
Honda Civic (2006 - 2015)
31
Jul 11, 2009 03:36 AM
'00Accordster
Oct 12, 2008 08:53 AM
Francesco
Honda S2000
25
Dec 23, 2005 08:34 AM
drdavidge
Sep 6, 2002 01:36 PM
