Where does this connect to?
Old Sep 27, 2012 | 11:02 AM
zoharj's Avatar
Default Where does this connect to?
I just bought a 92' VX with a not original VTEC-E. There are three things that i dont understand
First there is a loose tube. See the tube I am holding in the fist picture. It goes into the intake where i circled. But where does the other end go?
Also in the first picture on the right i circled something in red. What is that? What do i plug into that?
Also there is a loose wire. I think that wire goes to the EGR, is that correct? In the
Thanks so much!
Old Sep 27, 2012 | 11:42 AM
Former User's Avatar
Default Re: Where does this connect to?
What engine was swapped in? What ECU?
The green circled hose goes to the PCV/breather box.
Old Sep 27, 2012 | 11:58 AM
zoharj's Avatar
The ecu is p07. All i know about the engine is that it says vtec-e on it. I think its a d15z1 but im not sure. How do i check?
Old Sep 27, 2012 | 12:00 PM
The block and head have names/codes stamped on them.
Old Sep 27, 2012 | 12:13 PM
EX-T's Avatar
Yeah, look on the engine block by the transmission near the radiator. The engine code is stamped there. You might have to clean it off with a towel to be able to read it.
Old Sep 27, 2012 | 12:20 PM
zoharj's Avatar
Ok wheres that?
Old Sep 27, 2012 | 12:30 PM
HondaPartsHero's Avatar
Technical Hero
Old Sep 27, 2012 | 01:32 PM
mrspeedy69's Avatar
If i'm not mistaken that looks like a y8 manifold, and in the first pic what you have circled on the right can be blocked off. I'm not 100% sure on that but I think so.
Old Sep 27, 2012 | 02:21 PM
Technical Hero
Pic one
Its for the air injection. Used on 99-00 D16Y8's. Looks like you have a frankenstein on your hands.
Old Sep 27, 2012 | 06:52 PM
zoharj's Avatar
hmm. So what do i do about the fuel injector idle air control valve? Should I plug it up? Or put a little air filter on it?
Old Sep 28, 2012 | 01:37 AM
Technical Hero
You can just use a hose and block it off.
dointhemzs
Nov 12, 2008 05:36 AM
shraz
12
Jul 30, 2006 09:08 PM
Maddox
Jul 21, 2004 06:19 PM
oneslodx
Sep 9, 2003 05:55 PM
PSU-TEG
Dec 10, 2002 02:44 PM
