Hondas are like Computers sometimes.
Old Oct 17, 2002 | 07:45 AM
Superhatch's Avatar
Default Hondas are like Computers sometimes.
I replaced the o2 sensor yesterday, code 1 went away, but code 20 stayed. reset the ecu and this morining I was code free. I'm getting code 1 and code 20 again, but only after I drive for about 15 min. Then I can reset the ECU and Im fine for another 15 min. Then it will start chugging...but only when im driving. I can rev to 7k no problem if im in neutral. I DONT GET IT!!!!!
-Jake
[Modified by SuperHatch, 10:57 AM 10/17/2002]
Old Oct 17, 2002 | 08:00 AM
E-AT_me's Avatar
Default Re: Hondas are like Computers sometimes. (SuperHatch)
i have a mac and a crx with a b16a.. both with no problems..
Old Oct 17, 2002 | 08:14 AM
USDM 4G VTEC's Avatar
check all your grounds.... take the gnd cable and sand paper the contacts to the gnds, even the 2 plugs that are on the wall behind the right headlight
that was doing my code 20....
Old Oct 17, 2002 | 08:32 AM
spettinger's Avatar
is this in the 90? or your new king prepped hatch?
Old Oct 17, 2002 | 09:02 AM
Superhatch's Avatar
Default Re: Hondas are like Computers sometimes. (wreckedhatch)
The king prepped. I'll check the grounds, thanks for the tip...but that wouldnt explain why the o2 sensor fails every once and a while.
-Jake
Old Oct 17, 2002 | 10:58 AM
Superhatch's Avatar
o.k. so i drove it home from work. Tach still gets jumpy. if i kept it under 4000rpm i did alright...but if i mashed the gas, or tried to accelerate higher than 4k it stuttered and fell on its face a couple times. dizzy? fuel filter/pump ?
-Jake
Old Oct 17, 2002 | 11:10 AM
spettinger's Avatar
are there any aftermarket electronics on it? such as an AFC or ITC? my vote is to earth ground that mother with some 4 guage. ground it all, everything. ground! ahaha
Old Oct 17, 2002 | 11:54 AM
Home Skillet's Avatar
try formatting your motor.
Old Oct 17, 2002 | 11:56 AM
Superhatch's Avatar
Default Re: Hondas are like Computers sometimes. (Home Skillet)
No aftermarket electronics. Im using a d16 dizzy, but I have a sohc zc...that shouldnt make a difference though.
-Jake
spettinger's Avatar
agreed. make sure you have a cd rom installed, and use the "single cam for dummies" instructional disc. lousy car problems.
Old Oct 17, 2002 | 12:00 PM
Superhatch's Avatar
Buahahaha....I had no idea what you guys were talking about for a second...I was like ..Formatting? wtf?
-Jake
Old Oct 17, 2002 | 12:02 PM
LOL, sorry Jacob I just had to share with the fellow HT'ers.
SuperHatch (3:55 PM 10/17/2002): formatting my motor? Never heard of that, what do you have to do?
Home Skillet (3:57 PM 10/17/2002): no dude, i was making a computer joke. formatting is what you have to do to a hard drive whenever you erase everythinhg and start from scratch. LOL, sorry for the mixup.
SuperHatch (3:58 PM 10/17/2002): lol..i wasnt thinking about that at all...rofl....nice
Old Oct 17, 2002 | 12:27 PM
Superhatch's Avatar
Hey...I wouldnt have expected anything less
-Jake
Old Oct 17, 2002 | 04:20 PM
BeEfiEBuNz's Avatar
lmao!
Old Oct 17, 2002 | 04:27 PM
d-wreck's Avatar
Default Re: Hondas are like Computers sometimes. (BeEfiEBuNz)
note for anyone:
anytime any accessory or anything else is the car is electronically freaking out its always always something grounding or not grounding, and usually its not grounding.
id run new grounds to fix the problems
derek
Old Oct 17, 2002 | 09:58 PM
big pete's Avatar
Default Re: Hondas are like Computers sometimes. (d-wreck)
kick it a couple times....maybe it'll work
Old Oct 17, 2002 | 10:18 PM
spettinger's Avatar
Default Re: Hondas are like Computers sometimes. (big pete)
so you have a sohc zc in the new hatch? are there any wiring differences at all between that and an A6?
Old Oct 18, 2002 | 03:43 AM
Superhatch's Avatar
note for anyone:
derek
Bingo.....the thermostat ground was loose. I feel like kicking my own ****.
-Jake
Old Oct 18, 2002 | 05:41 AM
-Jake
well the gnds was making my clusters go all crazy, gave me 12V on the gnd side, fried me an alternator, wouldnt let my headlights, horn, or tailights work, and all other ****... and u tell me u cant explain how it hapen?? gnd ***** a lot of things!...
doom26464
Aug 26, 2008 07:45 PM
fryguy190
Mar 16, 2008 10:21 PM
.ShawnD.
Jan 28, 2004 03:34 PM
Timmah!!
Sep 9, 2002 11:29 AM
