daily driver stock sleeves 10.46@141
so last friday i had a pb of 10.45@141. i wanted to get it on camera and try to go faster but i only had a best of 10.46@141.. i have a bad shift from 1-2. Aaron lopez has been working with me to get it faster.. i hope you like the vid and please feel free to comment so i can learn more.. thanks
http://www.youtube.com/watch?v=ULp8q...ature=youtu.be
So here is my time slip from last night. My 60 ft was not the best ane I shift 1-2 very slow.
So the break down of my setup.
B18b1 block stock sleeves with golden eagle block guard.
Eagle h beam rods
Weisco pistons. 10.5.1
The head is a gsr with supertech springs and retainers
Stock valves
Skunk 2 pro1 cams
Golden eagle cam gears
Arp head studs
Ram horn manifold
Percision 6262 t4
Tial wasgate
Ebay rfl blowoff valve and ebay inttercooler and piping
70 mm skunk 2 tb with bbk intake manifold.
As far as suspention I have used kyb agx skunk 2 coilover with stock spring rate that I purchased from ipgparts.com.
I have a walbro 450 and run q16.
Eagle h beam rods
Stock valves
Skunk 2 pro1 cams
Arp head studs
Ram horn manifold
Percision 6262 t4
Tial wasgate
max is 28lbs
Yes i am very impressed. chad from noribilt tuned with the guidence of jason (stoopid)
yes, thank you very much all the patience and practice you have given me.
you have made be become a better racer all the way around. Had the car not bust a tube on that last past that you drove it would have been a 10.2x at minimum......
for those that doent understand. Aaron Lopez has tought me alot and tells me my 1-2 shift isnt fast enough. I let him drive it so i can see how i should drive it. he ran 2 tenths faster than i did but due to the right tube busting he didnt complete the pass. he was deff on a 10.2x pass or better.
thank you
thank you
m0t0rhead
Mar 7, 2003 08:49 AM
