OIL LEAK
ive had this problem since i bought the car, its leaking a greenish-brown-black with silver thing oil. earlier i pulled the vss out the transmission and saw the same oil sorrounding the gear of the vss, could it be a transmission oil leak? and where's the most common leak?
trans fluid is going to be red, or brown....
easiest way to tell if its trans fluid is dip a finger in it and smell it...if it burns your nose a bit....its trans fluid. it doesn't smell good.
well you said you took out the VSS and saw it there. Check that area. Also could leak from the fill, and or drain plug. Also where the axles go into the tranny. You have to clean/degrease everything and then go for a drive, come home and look where it's wet.
Open the hood, spray simple green or any other degreaser all over the tranny. Yes, go underneath and do the same. Use a brush to agitate the heavy stuff, then hose it all off. You won't damage anything. Don't spray directly on any wires or electrical stuff. Make sure the car is warm, not hot. Once you are done, you can start the car and drive to speed up the drying process.
holmesnmanny
Honda Civic (2006 - 2015)
Jul 14, 2016 05:45 PM
redCloud
Mar 24, 2010 09:26 AM
Tonyl507
Dec 8, 2006 09:32 AM
