Sohc non vtec zc w/ dpfi
Old Sep 26, 2012 | 03:13 PM
maiden424's Avatar
Default Sohc non vtec zc w/ dpfi
I am going to buy a zc sohc non vtec engine for my 90 civic std.. I want to use my dpfi manifold until I get more fund for a mpfi swap.. Can I do this? What ecu do I use and can I use my distributor off my d15b1 engine? Thank u in advance.. I need some help.
Old Sep 26, 2012 | 03:16 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Sohc non vtec zc w/ dpfi
Replace your engine with the ZC and reuse the manifolds and distributor. It'll be a one for one swap.
Old Sep 26, 2012 | 04:14 PM
maiden424's Avatar
Use my existing ecu?
Old Sep 26, 2012 | 09:01 PM
24TEN's Avatar
PHANTOM MENACE
Yes.
Old Sep 26, 2012 | 09:42 PM
maiden424's Avatar
Thanks.. I've been ripping my damn hair out behind this thing.
Old Oct 1, 2012 | 09:01 AM
maiden424's Avatar
Ok so another question.. The zc was made to be mpfi. Is my dizzy gonna work? Is it gonna run? I'm concerned about the crank sensors & such or does it not matter as long as I'm running the dpfi im& throttle body? Is it plug & play?
Old Oct 1, 2012 | 09:44 AM
24TEN's Avatar
PHANTOM MENACE
It'll be fine, general rule of thumb is match the distributor to the ECU.
Old Oct 1, 2012 | 11:18 AM
maiden424's Avatar
Ok then.. I'm getting my motor tomorrow from engine world in emeryville ca.. Gonna do the timing belt & seals & such.. We'll see how it go's.. Thanks for the help.. I'll most likely hav more questions later as this is my first honda swap.
crx2010
13
Oct 16, 2015 10:26 AM
Slobuild
Jan 7, 2013 06:14 PM
dmunoz
Aug 27, 2010 07:21 AM
osmbr
33
Jan 15, 2010 05:10 PM
dohc-crx
Mar 5, 2006 02:41 AM
