crx wont start?!
i have a 89 crx si and it wont start but the motor it cranks but wont start so i changed the fuel pump,dizzy,ignition coil.ignition module,spark plugs, etc after i did all that it still didnt wanted to start so then i changed main relay,ignition switch and same result..i changed all these part and theres no spark coming out and i dont know what else can it be or where to look at pretty much gave so can anyone help me or what else can i look at or be thanx..?
since when it dosent start did you change something... It Might be stupid but is your timing belt broken or is your timing is well set!??
Chek your rotor in your dizzy is it holding with the screw or else it will spin freely
well its been sitting for about a year bcuz i moved but my dad started once a week but i been trying to start it like two months ago ..yea my timing belt is good and its set and i replaced the rotor too
On my freind's car that allready happend that is alternator was seised and wasent turning.. just cuzz of the belt draging on the alt pulley it wasent starting... Didnt turn fast enought!! It happen often wen the car sits for too long.. so we removed the belt, crank it and vroummm like a new!!
Might be a bad ground... Grab some booster cables, clamp it on your engine one one end and on your body on the other end then try it... If it work change all your ground
Make sure the resistors box has power then with the test light check every whole and if doesnt light up then your resistors box not sending power, even if one dont light up you have to change it unless you find a way to bypass it
