Finally took my car to the dyno....
Old Oct 17, 2002 | 07:04 AM
dplatt's Avatar
Default Finally took my car to the dyno....
And remembered a lot of you wanted to see what kind of numbers I was putting down. Well, here's the extent of tuning with an hour on the dyno (16 pulls)...
Intake Cam advanced 8 degrees
Exhaust Cam at zero
Fuel pressure raised from 40 up to 45 psi
Timing at 16 degrees
I was hoping for a bit more, but am happy with my results. I think with some more time I and a stand alone ECU I think I could get even better numbers.
Large Image (may have to cut and paste)
And then a little fun video of my car on the dyno. Wish I could have had the video run all the way out to 9400rpm.....oh well.
Dyno 1
Old Oct 17, 2002 | 07:26 AM
vtec69's Avatar
Default Re: Finally took my car to the dyno.... (dplatt)
how big are your wheels?
Old Oct 17, 2002 | 07:31 AM
dplatt's Avatar
Default Re: Finally took my car to the dyno.... (vtec69)
17 x 7.5" Volk SE 37Ks.
Old Oct 17, 2002 | 07:36 AM
teg92's Avatar
Hey Dan! Impressive as always...
I was wondering what made you guys aim towards going with the odd cam phasing during tuning? What was it set at originally and what did the power band look like to make you decide on tweaking to +8/0 ? Thanks
Old Oct 17, 2002 | 07:43 AM
dplatt's Avatar
Default Re: Finally took my car to the dyno.... (teg92)
Rich, I gradually advanced the intake cam and each run it made more power. The idle kept getting worse the more I advanced it though, so I tried retarding the exhaust cam, and it actually hurt power even though it made the idle better. Now I'm running on the street at +8 and with the fuel leaned out at idle, it idles "okay". I've always heard that to make lots of power the Toda Bs, advancing the intake cam is the way to go. I guess that theory is correct.
Baseline WHP was 191 and baseline torque was 129.
Old Oct 17, 2002 | 07:55 AM
Brandon Chun's Avatar
Nice numbers Dplatt, 204 aint too shabby . What kind of plans do you have now?
Old Oct 17, 2002 | 08:03 AM
(__________)'s Avatar
Default Re: Finally took my car to the dyno.... (Brandon Chun)
what engine do you have and whats done?
Old Oct 17, 2002 | 08:06 AM
dplatt's Avatar
Default Re: Finally took my car to the dyno.... (steves98itr247)
Here's a list of mods for those interested.
Engine:
Fully Balanced B18C1 Block w/ JDM B18C5 Internals (11:1 CR), USDM ITR Top End (Head, Intake Manifold, TB), Portflow Headwork w/ Bronze Valve Guides, Toda Dual Valve Springs, Crower Titanium Retainers, Toda Spec B Cams, Toda
Gen 2 Cam Gears (+8, -2), RC 270cc Injectors, BBK 255lph Fuel Pump, STR Competition Fuel Rail, B&M CommandFlo Fuel Pressure Modifier (45psi), Toda Program OBD-1 P28 ECU, Apexi V-AFC (VTEC x-over @ 6600rpm), MSD SCI-L Ignition (Rev Limit @ 9400rpm), MSD High Vibration Coil, MSD Pro Distributor Cap, STR Cam Seal, Greddy 1.3 Radiator Cap, Mugen Thermostat.
Transmission:
GSR YS1 Cable Transmission (5-Speed), Quaife ATB LSD, Centerforce Dual Friction Clutch, 13lb. Lightened & Balanced Stock Flywheel, Tenzo R Short Shifter, Energy Suspension Shifter Stabilizer Bushing Set.
Intake:
RS Akimoto Funnel Ram II Intake, Custom Cold Air Extension.
Exhaust:
Toda 4-2-1 Header, OBX-R Resonated Test Pipe w/ custom 2.5" flange, Thermal R&D Classic SS Catback Exhaust.
Suspension / Handling:
Skunk2 Coilovers (lowered 2.5"), Koni Yellow Adjustable Shocks, Specialty Products Camber Kit (Front & Rear), OBX-R Front Upper Strut Bar (Polished), Suspension Techniques Front & Rear Sway Bars, Focuz Rear Lower Tie Bar.
Wheels/Tires:
17" Volk SE37Ks wrapped in 205/40ZR17 Kuhmo Supra 712s.
Brakes:
Brembo Cross-Drilled Rotors, Goodridge SS Braided Brake Lines.
Old Oct 17, 2002 | 08:10 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Whats your setup b/c I feel you can definately get more out of what you have now. I'm making 201whp with my stock bore B16.
Old Oct 17, 2002 | 10:17 AM
teg92's Avatar
Default Re: Finally took my car to the dyno.... (FrostyDC4)
Cool Dan, thanks for the information
[Modified by teg92, 2:18 PM 10/17/2002]
Old Oct 17, 2002 | 10:23 AM
Tomakit's Avatar
1.8l, sweet
Tom
Old Oct 17, 2002 | 10:36 AM
Jesse H's Avatar
really nice torque curve
Old Oct 17, 2002 | 10:49 AM
slowerthanu's Avatar
New User
I think he is making awesome power with only 11.1:1 compression ratio.
Old Oct 17, 2002 | 10:55 AM
OneFastLS's Avatar
Default Re: Finally took my car to the dyno.... (slowerthanu)
Baseline...191 whp? What the ****? What kind of engine do you have in there?
Old Oct 17, 2002 | 11:14 AM
aznmc16's Avatar
Default Re: Finally took my car to the dyno.... (OneFastLS)
wow.... very expensive project. how much did you spend?? 10G's??
Old Oct 17, 2002 | 11:19 AM
LOwrestling2001's Avatar
read the post.
Old Oct 17, 2002 | 11:40 AM
Kelvin96GSR's Avatar
25 Year Member
Default Re: Finally took my car to the dyno.... (LOwrestling2001)
wow very nice!
Old Oct 17, 2002 | 01:16 PM
Buckshot's Avatar
Default Re: Finally took my car to the dyno.... (Kelvin96GSR)
thats sick...hes makin power to 9k
i always had admired you from g2ic haha good job
Old Oct 17, 2002 | 01:27 PM
ku09's Avatar
Default Re: Finally took my car to the dyno.... (Buckshot)
really nice car! and times!
Old Oct 17, 2002 | 03:30 PM
obd2gsr's Avatar
that's a beautiful 2nd gen!!! great job!
Old Oct 17, 2002 | 03:34 PM
Duckz's Avatar
Default Re: Finally took my car to the dyno.... (obd2gsr)
love the red G2, nice job!
Old Oct 17, 2002 | 04:08 PM
94allmotor4doorgsr's Avatar
Default Re: Finally took my car to the dyno.... (duckz)
not bad
Old Oct 17, 2002 | 04:25 PM
B00ST2nR's Avatar
Default Re: Finally took my car to the dyno.... (94allmotor4doorgsr)
good numbers!
Old Oct 17, 2002 | 05:42 PM
.Chris.'s Avatar
Default Re: Finally took my car to the dyno.... (Skunk2nR)
hey guys, got what some might think is a dumb question here.....
Which GSR's are faster in the 1/4 G2 or G3 or is there no difference??
Buddy of mine told me G2's were faster. I didn't think there was a difference.
Old Oct 17, 2002 | 05:54 PM
stick's Avatar
Default Re: Finally took my car to the dyno.... (Black204GSR)
awesome #'s.
think about going to 18 on the timing.
bumping up compression since u have B's?
fuel pressure to 50 psi?
i think u can squeeze some more HP out of it.
