Car Won't Start (when hot)
Old Sep 26, 2012 | 05:08 AM
Quence's Avatar
Default Car Won't Start (when hot)
YES! i knw this problem been solved before, trust me i've read em all!.. ive seen a lot of solutions around the web but when i try things out still getting no where. basically i got a 94 honda accord ex. just like all the past threads, the car starts up fine in the morning night but when its time for me to get out of work the bastard cranks and cranks but wont start. it obviously sound like a fuel/spark problem but owell. so its been some time of the same, such that now i came with the trick of pressing the gas pedal while hitting it and after a few cranks it starts up, keep in mind the car is Automatic. after it starts up that way the idles are mad low to the point that the car shakes for like 10 seconds, then it goes up to around 2 to 3k which is my normal start up when cold.
Already replaced fuel pump, fuel filter, cleaned injectors (checkd resistance), distributor cap and rotor, spark plugs and wires, jumped connector, get no code. thought of being the Main relay and since my brother has the same car, tries his to see if there was any difference but NOTHING, and even after that i went to honda and got me a brand new relay for a long 90 bucks, the car started good with no problem until it got to sit in the sun again and here we are still dealing with this. btw the car has a brand new battery.
i know i just wrote a lot of ish..but i just tried to answer any question you may want to ask if you decide to give your 2 centavos.
Reallydatgood20
Jul 3, 2013 12:56 PM
bart simpson
15
Apr 6, 2010 12:21 PM
boostedpleasure
13
Oct 12, 2006 09:10 AM
vinuneuro
Oct 12, 2006 05:44 AM
Honda Sport
Jun 4, 2003 05:27 PM
