1994 honda civic hub bearing
Old Sep 26, 2012 | 01:50 AM
b20hondacivic's Avatar
Default 1994 honda civic hub bearing
one of my rear hub bearings are shot in the back... That explains all the loud rumble when my car is rolling. When i went to autozone i gave them my make and model of the car and when i got the hub assembly turns out it doesnt fit the spindle in the back. The hub currently on my car says on the bearing HU8005-39 and it has abs if that helps. Its also slightly bigger than the autozone hub. Any clue on what i can do to find out the bearing? Thanks
Old Sep 26, 2012 | 02:08 AM
jbpnoman's Avatar
Default Re: 1994 honda civic hub bearing
What trim is your car?
Old Sep 26, 2012 | 02:19 AM
1994 honda civic dx hatchback
dxs never came with abs but the hub thats on the car right now has abs... so i dont know which bearing i need
Old Sep 26, 2012 | 02:43 AM
jbpnoman's Avatar
Rather than going in depth to figure out exactly what kind of rear hub you have on your car, I did some searching and found out that HU8005-39 is an NTN Bearings part number.
http://www.ntnamerica.com/
Browse through their applications sections, or just give them a call. You can probably get a high quality direct replacement straight from them, as well.
Old Sep 26, 2012 | 02:49 AM
Thanks! i tried to google HU8005 i coudlnt find nothing. hopefully i can find something
Old Sep 26, 2012 | 02:55 AM
jbpnoman's Avatar
Yeah, it took some digging, and a couple translators. I'll give you credit for trying.
THIS is where I'm basing my information off of. More specifically, the following post.
mohon bantuanya, sya lagi cari sparepart bearing/laher roda belakang (kiri-kanan) utk honda eg6/ estilo jepang yg menggunakan ABS ...merek bearing NTN no. HU8005-29 lengkap dgn rumahnya...
coz udah nyari di toko sparepart ga ada, yg punya estilo lokal ga ada sensor gerigi ABS nya...
thanks
I don't know exactly what it means, and translators don't work well with Indonesian/Malay, but I do see NTN, a part number that's only one digit off yours, EG6, and ABS.
Old Sep 26, 2012 | 05:35 PM
yeah i really couldnt find anything, i guess i have to bring it to a shop now
Old Sep 26, 2012 | 08:25 PM
Mfoehrkolb's Avatar
So your car is disc brakes in the rear? Has an ABS line but it isn't hooked up?
Tugrol Choudary
Suspension & Brakes
Mar 27, 2018 10:50 AM
ajax68
Honda CR-V & Element
Nov 13, 2016 06:58 AM
simonettamt
Suspension & Brakes
Mar 2, 2014 07:46 PM
DACteg
Jun 9, 2008 07:29 PM
