10.12@151 6262 Integra.. Getting closer to 9's
My previous best pass was a 10.45@145 a few months ago.
Since then i found some weight and changed the clutch.
First pass of the day was the 10.12@151. I actually hit rev limiter crossing the line in 4th gear. I guess 24.5's and 9500rpm only get you that much lol
60ft: 1.653
330ft: 4.574
1/8th: 6.789@112.83
1000ft: 8.627
1/4 mile: 10.128@151
This was only at about 23-24psi in 3rd and 4th gear.
So the next pass i upped the boost in 2nd/3rd/4th. Should have been almost full boost in my car which is only 26psi. Upped the rpm to 9800.
60ft: 1.652
330ft: 4.567
1/8th: 6.911@110.94
1000ft: 8.627
1/4 mile: 10.29@151
So this pass was going to be better, until i missed 3rd gear....I noticed the trap in the 1/8th was down 2mph but still went the 151. I think it has a solid 153-154mph trap in it. But at this time i can only Bench race about what it should do lol.
I need to give it some more power in every gear and shift it like there is no tomorrow to get that 9 sec pass. I know it will do it, the power is there and mph shows it, i just need to drive it.
I only got 2 passes. On the end of that last pass the car shut off and would not start back up. No fuel or Spark. Brought it back to the pits and quickly diagnosed it and found the ECU fuse burned up for whatever reason. Threw another in there and tried to start the car but it quickly showed it had a problem when smoke started coming out of the dash area. Traced it to one of the main relay wires burned up. So there is an issue somewhere.
The car has never had any problems like this over the 6 years i have had it and i bought it BONE stock.
The car is Corner balanced, but i still have STOCK shocks and some Maxspeed coilovers. I think once i get some real suspension in the car it will do better lol.
Quick setup rundown:
Sleeved 84mm GSR
10.5:1 JE pistons
Eagle rods
Supertech Valve springs/Retainers
Ferrea 6000 IN/EX valves
Ferrea Keepers
B16 head
GSC Power-Division Turbo Cams
Victor X intake mani
Stock TB
FIC 2150's
Stock sumped fuel tank
Twin 255's inline
ETS Forward Facing Turbo manifold
ETS 4x12x24" intercooler
Precision 6262, T3 .82A/R
The car made 690whp@26psi on E98
Tuned on Crome Gold with an AVCR for boost control.
http://youtu.be/_QVW0LXYRaM
60ft: 1.653
330ft: 4.574
1/8th: 6.789@112.83
1000ft: 8.627
60ft: 1.652
330ft: 4.567
1/8th: 6.911@110.94
1000ft: 8.627
1/4 mile: 10.29@151
Sleeved 84mm GSR
10.5:1 JE pistons
Eagle rods
Ferrea Keepers
B16 head
Stock TB
FIC 2150's
Twin 255's inline
How much does the teggy weigh?
Awesome E/T and MPH!! Congrats!
I think this is the car Rico was telling me about the other day. What trans are you running in it?
The car makes really good power per psi, combo of all the right stuff and 10.5:1 compression seems to help. These cams made some good power over the ITR cams too. Car makes about 440whp@11psi.
The car scaled in right around 2400 with me and a half tank of E98. I have a sunroof delete, door bar delete, 5pt chromoly roll bar, no front or rear bumper supports etc....
lol on Crome.. thats pretty neato man, congrats. I'm sure you've gotten flack for using it..when its tuned and set correctly, it works well.
4.4 FD.
I used to have the 4.26 FD and i liked it, but got a deal on this trans with the dff.
looking solid! Lets see some vids! Either from you road racing or at the track, on street or slicks. Your threads always amaze me.
Congrats are in order man, 151 is rolling out.
Thanks
http://youtu.be/fpw9pY4m_EE
11.8@133 on street tires
http://youtu.be/Rf__fpTOxhY
Stock Axles.
150 traps.
